FixHub Error Codes
Error Code #1, Battery Error - Charging Halt
  • The Power Station’s battery pack has accumulated a charge that exceeds the battery charge capacity.
    • This causes the battery pack to stop charging.
Error Code #2, Battery Error - Tool Error
  • The Power Station’s battery has been disconnected.
    • This causes the power station to stop any power being supplied to a connected tool.
Error Code #3, Battery Error - Charging Halt
  • The Power Station’s battery pack has not been fully charged when connected to a power source for 4 hours.
Error Code #4, Battery Error - Charging Halt
  • The Power Station’s battery pack temperature has exceeded 45 °C.
    • This causes the power station to prevent any charging of its battery.
Error Code #5, Tool Error - Sensor Disconnect
  • The Soldering Iron’s tip has been disconnected.
    • This causes the power to be shut off to the iron’s heater.
Error Code #6, Tool Error - Actuator Fault
  • The Soldering Iron’s target temperature has been exceeded.
    • This causes power to be shut off to the iron’s heater.
Error Code #7, Tool Error - Actuator Fault
  • The Soldering Iron’s target temperature has not been reached within the required time.
  • This can also be caused by a loose connection with the tip; try reseating the soldering tip.
Error Code #8, Hub Overheating - Tool Shutdown
  • The Portable Power Station’s Main Board temperature has exceeded 105 °C.
    • This causes the power station to shut off both itself and the soldering iron heater.
Error Code #9, Hub Overheating - Tool Shutdown
  • The Soldering Iron’s Power Delivery Microcontroller(PD MCU) temperature has exceeded 150 °C.
    • This causes the power station to shut off the soldering iron heater.
Error Code #10, Tool Overheat - Tool Shutdown
  • The Soldering Iron’s Main Board has exceeded a temperature of 150 °C.
    • This causes the iron’s heater to be shut off.
Error Code #11, Cable Error - No Data Connection
  • The cable connection between the tool and the power station is unable to transmit data properly.
    • This causes the Power Station to continue powering the connected tool, but it cannot read additional data or modify any of its settings.
Error Code #12, Tool Error - Tool Freefall
  • The tool connected to the Power Station has been dropped.
Error Codes #13 & 14, Hub Overheating - Port Throttling
  • The Power Station’s front ports have a temperature that has exceeded 105 °C.
    • This causes power to be shut off to the corresponding port(s).
Error Code #15, Battery Error - Discharging Halt
  • The Power Station’s battery pack temperature has exceeded 60 °C.
    • This causes the power station to prevent any further discharge of its battery.
Error Code #16, Battery Error - Battery Warm (Not Hot)
  • The Power Station’s battery pack is getting warm.
    • This is only a warning, normal function continues.
Error Code #17, G0 Firmware Corrupt
  • The G0 processor is not functioning correctly
    • Update the firmware to restore normal operation
Error Code #18, Firmware Mismatch
  • The tool firmware version does not match the Power Station firmware version.
    • Some newer features may not be available.
    • Recommend updating tool and Power Station to latest firmware.
Please contact customer support if you need additional help with your FixHub Portable Power Station or Smart Soldering Iron.
Author
with
Kara Piepenbrink
8,347 Reputation
21 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 134
All Time: 2,881
