Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Dead/Uncharged Battery
Your Fitbit Surge battery is not charging.
Fitbit Surge Needs to be Pluged In
Check to make sure that your charger cable is securely plugged into the back of your FitBit. Next, plug the other end of the charger cable into the USB port on your computer. You may need to clean your tracker and brush any debris away from your charger.
Faulty USB Port
If your charging cable is securely plugged into your device and it is still not charging, the USB port may be faulty. Test your computer’s USB port by inserting a different device into the port and checking if it is functioning. If the port is faulty, plug your charger into a different port or a different computer.
Faulty Charging Cable
If your USB port is functioning and your device is still not charging you may need to purchase a new charging cable.
Battery not functioning
If none of the above troubleshooting solutions work, the battery in your device may be broken. If this is the case you will need to replace your battery or consider purchasing a new device.
Wrist Band Tearing
You have trouble with your wristband tearing at the screws.
Faulty Wristband
The band alone is not replaceable because the electronics are built into the strap. Because of this, the whole device will need to be replaced. Check the warranty on the device; you could qualify for a replacement. Customer Support can be reached through live chat, phone, or email. Go to fitbit to access this information.
Unresponsive Home Button
Home button is not returning you to menu
Faulty Clock Face
Change the clock face using your mobile device. Go to your account on your ios device. Go to the clock face and select a clock face. Sync your tracker.
Fitbit Surge Needs to Restart
Press and hold the home and select buttons (on the left and bottom right of the watch) and hold for 10-15 seconds until you see the screen flash or the light start to dim. Let go of the buttons and wait until the screen turns off completely. Wait 10 seconds and press the home button to turn the Surge back on.
Dead or Broken Button
If neither of this options work, your button might be dead or broken and you will need to contact customer support at http://help.fitbit.com/?cu=1
Unresponsive Touch Screen
Touch screen is non-reactive.
Faulty Hardware
If this option does not work, it is most likely a hardware issue and you will need to contact customer support at http://help.fitbit.com/?cu=1
Not Syncing with Computer
You have trouble syncing your fitbit to your computer.
Fitbit Surge Needs to be Re-synced
Prompt Fitbit Connect to sync with your tracker by clicking the Fitbit Connect icon on your computer and logging in. Then, under Main Menu, click Sync now. If you see a message saying your tracker can’t be found, click your Fitbit’s home button. For instructions on how to sync with different types of devices go to Sync Fitbit
Fitbit Surge Needs to be Charged
Charge your Fitbit and try syncing again.
FitBit Surge Needs to Restart
Restart your Fitbit Surge and try syncing again.
Fitbit Connect Needs to be Uninstalled and Reinstalled
You might need to reinstall Fitbit Connect on your computer. Go to Reinstall Fitbit Connect for instructions on how to reinstall Fitbit Connect.
Author
with
Angela Pitts
1,190 Reputation
4 Guides authored
USF Tampa, Team 1-3, Leahy Fall 2016 Member of USF Tampa, Team 1-3, Leahy Fall 2016
USFT-LEAHY-F16S1G3
3 Members
48 Guides authored
9 Comments
Red light on right side of face stay on all the time . Why or what is this light
Sandy Rasmussen - Reply Share
My fitbit surge stuck in demo mode.plz help me
izwande 86 - Reply Share
My Fitbit Surge comes on when plugged in to charger, but can’t get it to come on when unplugged.
ginaross65 - Reply Share
yeah mine too
RoyalWithCheese6 - Reply Share
Hi guys, my Fitbit surge is not charging, I think issue with battery,
Is it worthwhile to put a new battery in ? thanks
A Imran - Reply Share
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 38
All Time: 22,503
