Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Poor brake performance
Brakes don't stop well, or at all
Brake-release Lever not engaged
Make sure that the brake-release lever is not in the released position. This can happen if the bikes wheels were taken off recently.
Brake pads need adjusting
Sometimes the brake pads can fall out of alignment with the brake contact on the wheels, causing poor braking performance. This can be resolved by loosening the shoes using an allen key and adjusting them to meet the breaking surface.
Bent caliper
In certain situations the entire caliper can come out of alignment. This can be fixed by pulling the lever hard to reset the caliper or by physically rotating the caliper by hand.
Incorrect tension on brake cable
Try rotating the Barrel Adjuster on the caliper where the cable is inserted.
Skips a gear when shifting
When trying to change gears, the chain will jump multiple gears
Incorrect barrel adjuster tension
The barrel adjusters are effectively tensioners in the shift cable that keep the derailleur where it needs to be. Try rotating each one counter-clockwise/clockwise until the derailleur is in the correct gear.
Chain randomly falls off
When shifting or while riding the chain will randomly fall off
Derailleur limit screws out of adjustment
If the chain falls off when only in the highest or lowest gears, try adjusting the derailleur limit screws. They are labeled H(High) and L(Low) and are located on the derailleur itself.
Incorrect chain type
Although all chains look alike there are many different variations and types. Make sure the chain is valid for a 10 speed drivetrain.
Bike tube continuously punctures after tube replacement
Tire goes goes flat immediately after changing
Check inside of tire for debris
If tire goes flat after replacing the tube, there could be debris inside of the tire itself or something inside of the rim. Sharp objects can be and often are the culprit.
Author
with
Ryan Marschall
123 Reputation
1 Guide authored
USF Tampa, Team 1-21, Donnelly Fall 2014 Member of USF Tampa, Team 1-21, Donnelly Fall 2014
USFT-DONNELLY-F14S1G21
1 Member
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 657
