Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Camera Records Blurry or Washed Out Video
The camera recording component will not record.
Camera Lens is Dirty
If camera lens is dirty get a clean cloth and light cleaning solution. Put a modest amount of cloth cleaning solution on the cloth. Gently rub the cloth on the camera lens in a circular motion. Let dry, turn camera on and try recording again.
Camera is Overheated
Ensure camera is not overheated by powering off the camera. Once camera is full powered off place camera in a space room temperature for twenty minutes. After twenty minutes, power camera back on and see if it is recoding properly.
Camera Lens is Broken
If camera is still not recording properly after ensuring the camera lens is clean and the camera is not overheated it can be determined that the camera is broken. Replace the camera using this guide FLIR FX.
Cannot Assemble the Different Parts of the International USB Power Adaptor
Unsure how put and take off the two parts for the international USB power adaptor
Cannot Install the International Prongs on the International USB Power Adapter
Make sure prongs on the adapter are down. Look at the replacement prongs you wish to install and find the arrows and “PUSH”. Hold the prongs in a manner that shows the arrows facing down and “PUSH” upside-down. Place the prongs under the adapter and push up.
Cannot Remove the Prongs from the International USB Power Adapter
Look at the replacement prongs and find the arrows and “PUSH”. Push the prong down in the direction the arrows are facing. The prongs should slide off and the adapter should show the original prongs again.
Camera Will Not Power On
When the power button is pushed, the camera will not turn on.
Depleted Battery
Ensure that the battery in the camera or stand is charged by attaching the USB cord to the camera or camera mount and power adapter. Plug in the power adapter and allow the camera to charge for 30 minutes before pressing the power button again. While the camera is charging the record button at the top of the camera will be an orange color.
Battery is Not Holding Charge
If after charging for 30 minutes and the camera will not turn on, or when the charger was plugged into the camera the record button did not light up, follow this replacement guide to help change the faulty battery FLIR FX.
Camera Will Not Connect Via USB
When the camera is plugged into the power adapter nothing happens.
Dirty USB cord
If the USB cord is not properly placed in the power adaptor or dirty, the camera will not connect. Clean the port and cord, and make sure the cord is connecting with the power adapter and see if record button turns orange.
Faulty USB Cord
If the USB cord is bad, the camera will not connect with power adapter and charge. To test if this is the problem borrow a USB cord and test it with the Camera to see if these problems still occur.
Camera Does Not Hold a Charge
Power cord will not charge the camera and it will not turn on.
Power Cable is Not Properly Seated
First, make sure your camera head is completely connected to the stand. Once you hear the clicking sound confirming this, insert the power cord on the opposite side of the power button, until you see the recording button light up orange. If the light on the button does not come on, first try a new outlet plug.
Power Cable is Frayed or Severed
If there proceeds to be a problem, there might be a problem with the power cord itself and you may need to seek further assistance. See FLIR FX.
Author
with
Emily Bell
392 Reputation
3 Guides authored
2 Comments
Have a earlier model flir thermal and it's showing the object upside down when you look through the lens
Joe Johnson - Reply Share
Screen is pure white can't remove turn on or off, please advise TG165-X new camera
robert burton - Reply Share
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 29
All Time: 7,769
