Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Eviant won't turn on
Can't get your MT7001 to turn on? Try this…
Holding Power Button
Hold down the power button located on the upper right hand side of the tablet for 30 seconds or until the screen turns on.
Charging It
Plug the charger into the micro USB port located on the bottom of the Eviant.
Faulty Battery
The battery is not replaceable so therefore it is not fixable.
Audio is Distorted or No Sound Out of Speaker
The sound coming out of the speaker doesn't sound right or there is no sound at all? Try this...
Volume Down
If there is no sound coming out of the speaker make sure the volume is not on mute and is turned up.
Faulty Speaker
If there is still no sound or the sound is distorted you can change the speaker.
MT7001 Wont Charge
When the Eviant is plugged into the charger it doesn't seem to be charging? Try this...
Faulty Charger
Make sure charger is working, if not replace charger.
Faulty Charging Port
If the Eviant Tablet still won't charge replace the charging port.
Faulty Battery
If the tablet still won't charge then the battery is damaged and cannot be replaced.
Audio is Distorted or No Sound When Using Headphones
When the headphones are in the sound is distorted or there is no sound? Try this…
Volume Down
If there is no sound out of the headphones make sure the volume is not muted and is turned up.
Faulty Headphones
If there is still no sound or if it is distorted then make sure the headphones are working properly.
Faulty Headphone Jack
If the sound is still not working properly then the headphone jack needs to be replaced.
Dim Screen
The screen seems to be dim and is making it hard to see? Try this…
Brightness Down
If your screen is dim make sure the brightness on the device is turned up.
Faulty LED
If this does not work then the LED may need to be replaced.
Faulty Circuit Board
If the LED is still not working then there is an issue with the circuit board.
Author
with
Jillian Gamblin
1 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 15
All Time: 1,639
