Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Motor will not start
No matter what you do, you can't get your vacuum to turn on.
Power switch is not turned on
Make sure you have pressed the power switch into the on position.
Check the socket
Plug a different device that you know is working into the socket to make sure the socket is okay.
Vacuum does not clean carpet
You keep going over and over the same spot, but you still can't pick the dirt up off of the carpet.
Full dust cup or clogged filter
Empty, clean, or see Eureka AirSpeed Bagless Zuum Vacuum Washable Filters Replacement guide to replace the dust cup filter.
Faulty hose or valve assembly
Make sure air path selector know is turned to the floor setting and there is not a blockage in the hose.
Worn, cut, or out of shape belt
To replace a worn or cut belt, see Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement guide to replace the belt.
Incorrect carpet height setting
Turn carpet height selector to another setting.
No suction at the end of hose
You try and clean the baseboards and corners, but the hose won't suck up any cobwebs.
If filter is clogged beyond cleaning, see Eureka AirSpeed Bagless Zuum Vacuum Washable Filters Replacement guide to replace the filter.
Faulty hose or damaged hose
If the hose is damaged, see Eureka AirSpeed Bagless Zuum Vacuum Hose Replacement guide to replace the hose.
Vacuum is hard to push
Even on hardwood floors, you struggle to push the vacuum.
If the belt is damaged, see Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement guide to replace the belt.
Burning smell
You begin using the vacuum and something smells like burning rubber.
Brush roll will not turn
If the brush roll will not turn, see Eureka AirSpeed Bagless Zuum Brush Roll Replacement guide to replace the brush roll.
Celina Burchett
1,122 Reputation
8 Guides authored
Clemson, Team 2-2, Benson Fall 2014 Member of Clemson, Team 2-2, Benson Fall 2014
CLEM-BENSON-F14S2G2
4 Members
96 Guides authored
28 Comments
Won't start, electrical outlet is good, there is power. New bag, no dirt around switch, no breaker flipped, power cord is intact. Still won't start. Now what?
7ohnnyramone - Reply Share
My vacuum is brand new. I have used it once. Today as I vacuumed it just randomly shut off and now it will not turn back on. Any ideas why and what needs to be done??? Power outlets are good and I have checked everything with the vacuum. Like I said its brand new!
Jennifer - Reply Share
Same as the others. The vacuum stopped running and will not come back. Less than 3 weeks old. AVOID BUYING THIS PIECE OF CRAP!!!!
Not That Guy - Reply Share
Same as others too. Ours is fairly new. Won't come back on. VERY frustrating since we thought were upgrading and getting a better vacuum.
jakewaits - Reply Share
Same problem brush wont turn and shouts down and wont come back on for a half hour,I checked the belt it was ok,So i fixed it i put it in the trash no more problem.PS IT WAS ONLY USED 2 TIMES .Dont buy a Eureka AirSpeed Bagless sweeper
cross571 - Reply Share
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 34
All Time: 37,340
