Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Unit will not power on
If your device will not turn on it may be a result of low battery power. Ensure that the device is correctly connected to the charger before attempting to power on again.
Unit spontaneously turning off
If your Ematic EXP8 turns off spontaneously, this could be a result of insufficient battery power. Ensure the unit is correctly connected to the charger, and let charge fully before using again.
Unit connected to charger but not charging
It is possible that it this could be due to a faulty charger. Replace charger.
No audio
Use volume controls on top left side of the unit to make sure the volume is turned on. If turning the volume up is unsuccessful replace faulty speaker.
Computer not recognizing device
Look for any damage on USB cable, if damaged replace USB cable. If USB cable looks undamaged it could be the operating system's inability to support unit. Check the manual for systems compatible and install or update a compatible operating system.
Author
with
Cassandra Ralph
43 Reputation
0 Guides authored
Montana Tech, Team 3-1, Shirk Fall 2015 Member of Montana Tech, Team 3-1, Shirk Fall 2015
MTUM-SHIRK-F15S3G1
3 Members
12 Guides authored
1 Comment
Very nice troubleshooting page! Your URL is formatted correctly, and all of the issues addressed in the page are common problems. I would add more information into the problem descriptions to make sure the user knows what issues to look for in their device. For example, in the section "unit connected to charger but not charging," add another possible problem the device could have instead of only saying "replace charger." Also, feel free to use articles, (a, an, and the), to add more clarity to the page.
Jessica Jones - Reply Share
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 496
