Red LED will not turn on.
Dead Battery
Typically when the battery dies the LED will no longer turn on and noise will not come out of the speaker. Try replacing the 9-Volt Battery.
Bad Solder Connections
Bad solder connections can be spotted with the naked eye. If this is the problem then you may find some cold welds, which means the solder did not settle right giving it a scuffed look instead of shiny. The other problem could be that a sufficient amount of solder was not added to area of the connection. Using a multimeter, check the voltage across each component. Begin the testing at the positive terminal of the voltage source and systematically check through the circuit until you find a component that has a voltage reading of zero. Try to solder this connection again.
The LED turns on and the speaker makes ambient noise but I cannot receive any radio signals
The first connection you may want to test is the capacitor labeled "C-22." This capacitor amplifies the radios capacity to receive radio signals. If there is no current flowing through the capacitor then you may want to replace the capacitor or solder the connection again. If the C-22 capacitor is working properly then you may want to systematically check each connection again until you locate a component that has 0 voltage passing through it. Try soldering this connection again. If this does not work then you may have to get a replacement for this component.
Charles Riel
218 Reputation
1 Guide authored
Charlie Riel Member of Charlie Riel
Community
1 Member
12 Guides authored
12 Comments
Catches radio signals, check. Hearable, not a snowball's chance in !&&*.
the117doctor - Reply Share
Like the censor
Led light works. No sound and U2 semiconductor becomes very hot after a few second? Suggestions?
David - Reply Share
I have same issue.
Chris Moore - Reply Share
You put the U2 in backwards. Probably fried it when it got hot.
Curtis Gilreath - Reply Share
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 36
All Time: 4,717
