Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Brush bar Has Trouble Rotating
Loose Fastener
Within the carbon fiber tool there is a fastener marked with a padlock that may come loose overtime and heavy use. To refasten the padlock follow the Brush Bar Replacement and proceed to tighten the lock marked with a padlock with a quarter or other convenient coin.
Clogged Brushbar
To replace or clean the Brushbar within the carbon fiber tool: Dyson Support
To replace or clean the Brushbar within the mini motorized tool: Dyson Support
Machine Displays an LED Light
Flashing Blue Light
This light means your Dyson vacuum battery is running low.
Fast Flashing Blue Light
Indicates no power or a temporary fault including blockages in the filter. Deep cleaning your Dyson How to Deep Clean your Dyson Vacuum
Amber Light
Indicates that there is no power or temporary fault such as the machine is either overheating or working in too low of temperatures.
Flashing Red Light
The red flashing light indicates that there is a more serious problem with the vacuum and it needs repair. To find out what is wrong with your Dyson or ask for additional help, call the Dyson support: 1 (844) 679-1647.
More on the Dyson LED lights: Dyson Support
Turning Off Mid Use
Blocked Filter
Your vacuum may automatically shut off if large items are blocking the tools or nozzle. To resolve this problem either remove the debris or wash the filter. Here is some additional help: Clearing Debris and Cleaning the Filter
Flashing Light
A flashing light indicates that there is something wrong with your device and this may lead your vacuum to turn off. To fix this please refer to the "Machine Displays an LED Light" section with or call Dyson for additional help: 1 (844) 679-1647.
Suction Power Severely Lacking
Blockage Within the Filter
If your filter is blocked it is necessary to disassemble part of your Dyson V6 Motorhead for cleaning.
Device Overheating
Max Mode Overused
If the device is used on max mode until the battery is drained, amber LED will flash, indicating device requires a few minutes to cool down before charging.
Mark Sunga
199 Reputation
0 Guides authored
Cal Poly, Team 22-6, Maness Winter 2017 Member of Cal Poly, Team 22-6, Maness Winter 2017
CPSU-MANESS-W17S22G6
4 Members
60 Guides authored
129 Comments
Brush Bar will not rotate.
Paul Calvert - Reply Share
Brush Bar will not rotate at all.
What does it mean when the Dyson V6 Motörhead + pulsates on and off six times, and again when you push the on button again, over and over?
George Williams - Reply Share
Hi, this happens when the machine senses it cannot pull enough air through the machine.
Usually it's because the filter is not clean enough. To check if it's the filter then take the filter out and try switching machine on. If it now works then the problem is the filter. Wash the filter by outing it in your washing machine. Rinsing it under the tap is not sufficient enough and leaves it soaked in water. The washing machine method leaves it almost dry and it smells nice too. NB - Dyson won't tell you this for fear of damage occurring to your washing machine. No damage will occur.
Dyson Solutions - Reply Share
Good gouge. Mine was doing the same thing, but it was the flapper valve stuck shut, some cat hair and debris had gotten lodged. But once I knew I was looking for a clog it was a quick find, thanks!
Kent Nichols - Reply Share
Past 24 Hours: 6
Past 7 Days: 16
Past 30 Days: 61
All Time: 388,740
