Vacuum cleaner does not start
  • Motor defective (remove and check motor guide).
  • Cable or contact in cable reel defective (replace cable reel).
  • Wiring between cable reel and motor defective (check for loose connectors or broken strands when disassembling)
  • Power button does not operate switch (straighten plastic parts, replace if necessary)
  • Switch defective (replace switch)
Fuse blows, even when the switch is in OFF position
  • Short circuit in cable or cable reel (replace cable reel)
Fuse blows when the switch is on
  • Damage to the rotor windings. Sometimes the motor still makes a brief noise until the fuse blows (replace motor)
  • Rotor blocked and motor draws overcurrent (remove the motor, try to clear the blockage, and test motor).
  • Circuit is not rated for inrush current (use the higher fused circuit, 10 amp fuses will release even on some vacuum cleaner models without a defect, use inrush current limiter).
  • Short circuit in the connecting strands between switch and motor (replace strands).
Motor loud, little suction power
  • Individual windings failed (replace motor), see also section "Little suction power"
Smell of burning or electrical fire
  • Strong collector fire (replace motor).
  • Combustible dirt deposited in motor (check motor)
Smells musty
  • Post engine filter is torn (replace filter).
  • Post engine filter completely clogged (replace or clean filter)
  • Dirt or mold throughout the unit (disassemble and clean).
Low suction power, sometimes accompanied by whistling noises
  • Leakage
Low suction power
  • Post-motor filter clogged (replace or clean filter).
  • Large foreign body in the supply line (remove)
  • Safety valve jammed (unjam it)
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
0 Comments
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 59
All Time: 3,240
