Unlisted
This wiki will not appear in search results, but can still be viewed by anyone!
  1. Check your batteries are fully charged before takeoff.
  2. Conduct a 'nudge' test before takeoff, once the flight controller is armed.
    • With some flight controllers (3DRobotics, DJI), the drone will respond to roll/tilt input before leaving the ground.
      • Forward pitch should result in an increase in the rear motors speed.
      • Left roll should result in an increase in the right motors speed.
  3. Check vehicle indication lights and telemetry data if available.
    • 3DRobotics and DJI flight controllers have indication lights for GPS and arm status.
    • Errors in GPS, compass, and calibration are easy to spot with telemetry data.
David Hoyt
4,053 Reputation
39 Guides authored
Cal Poly, Team 25-89, Amido Spring 2010 Member of Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Members
564 Guides authored
2 Comments
Excelente información.
manuelbeltran - Reply Share
Great List, there is also an article here which talks about the stuff you need before you leave, don't forget your SD or extra batteries like I did. http://dronewisdom.com/drone-checklist/
jbabin1 - Reply Share
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 33
All Time: 2,257
