Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Screen won't turn on
You're pushing all the buttons but the screen still won't turn on.
Did I put the battery in?
You were so excited to get your new gadget out of its box and into your hands. Make sure you inserted the battery into the device. If your battery is in but the camera screen still won't turn on, then read on.
Power off and back on
Maybe your device just decided to be stubborn and needs a reboot. Give it a try!
Is the battery in correctly?
Before you decide your device is gone, just make sure that you have the battery lined up the correct way. If this doesn't solve your issue, read on.
Drained/bad battery
If your camera won't turn on, the battery may need charging.
Lens Problems
"You're taking pictures with your device, but there just seems to be something wrong with the lens."
Is it dirty?
The lens is one of the most affected areas of a camera that gather dust. This could have easily happened without you knowing, so just wipe the lens off and make sure there is nothing on the lens.
Is it broken?
Look at the lens. Make sure there are no scratches or cracks in it. If there is, you likely need to replace the lens completely.
My camera has taken great shots before, but it just won't right now
If your camera is just acting weird, it's always a good idea to shut it off and turn it back on to see if this will solve your problem.
Battery
My device won't turn on
If your camera won't turn on, make sure your battery isn't dead. If this doesn't resolve your issue, read on.
Battery inserted incorrectly
If your battery is charged, but the camera still won't turn on, make sure you're lining up the battery the correct way.
Battery won't hold charge
If your battery stops holding a charge, you make need to replace it for your camera to work.
Buttons
Your device powers on, but no matter how hard you push, the buttons just won't work.
Was there a spill?
If your buttons appear to be sticky to the touch or when pressure is applied, make sure there is nothing on them or in between them. The smallest amount of soda can make your buttons sticky. Wipe the buttons with a wipe to see if your issue is resolved.
Buttons still won't work
If the buttons on your device just don't work, you may need to replace them.
Author
with
Ruru Idahosa
16 Reputation
0 Guides authored
Baylor, Team 10-16, Williams Fall 2015 Member of Baylor, Team 10-16, Williams Fall 2015
BU-WILLIAMS-F15S10G16
3 Members
48 Guides authored
9 Comments
The battery charges to full capacity. When I turn on the 720 the logo "Get Out There" shows on the screen for a few seconds then goes away and only a lighted screen shows. From there I cannot turn it off, select menu, record, or anything else. I have to pull the battery to turn it off. What can I do to fix this problem?
roywilkowski - Reply Share
My drift ghost XL won’t power off?any ideas,pls
Robert Campbell - Reply Share
We have same issue. Did you figure out a solution?
Cindy Russell - Reply Share
Ghost X Drift arrived today used it in the house for 10 minutes. Come to turn it back on after downloading app. Now it won't turn on.
I have charged it up for 2.5 hours. No light came on to show its charging, and still not working. Took battery out replaced the same battery. Still not working.
Any ideas or is it a pain in the arse return
k.smith33 - Reply Share
I have exactly the same problem…
Any ideas ??
Luis de la Fuente Klein - Reply Share
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 30
All Time: 5,733
