Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Screen is Blank
Your dragon touch screen no longer has picture and is black.
Needs to be Charged
The device is probably low on power and will need to be charged. If your charger is in good condition let the device charge for half a minute and wait for results. The device should be in working condition.
Display is broken
After long use of wear and tear the screen may go bad and will not show anything on the screen. Replacing the screen should return the device back to a working stage.
Faulty Battery
A dead battery will cause the screen to be blank and the device is not getting any power. Change the battery and everything should return back to normal.
No Volume
When you try and turn up your Dragon Touch and there is no sound.
Batteries are low
If the volume is not working the batteries may be low and may need to be changed. Change the batteries and see if you get different results.
Buttons are broken
Sometimes the device buttons after a lot of use and time, they tend to go bad. The button will need to be replaced to be able to have volume again on the device.
Will not Charge
When your Dragon Touch is plugged in for an extended period of time, and will either not hold charge or not turn on.
Charger Port is Damaged
If you’re having trouble charging your device the charger port inside of the device may be damaged. The little pins could be bent causing your charger to not give the device any power. Replacing the charger port will fix this problem.
Internal Parts are broken
If it is still not charging then most likely parts inside the device are broken and will need to be changed.
Kirk Stenftenagel
37 Reputation
0 Guides authored
IUPUI, Team 1-7, Baechle Fall 2016 Member of IUPUI, Team 1-7, Baechle Fall 2016
IUPUI-BAECHLE-F16S1G7
4 Members
0 Guides authored
3 Comments
It not showing nothing
Tina Farris - Reply Share
How do you replace the charging port
jessie - Reply Share
How do I replace the charging port
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 26
All Time: 3,749
