Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Screen Is Black
The screen does not show anything
Drained or dead battery
The battery might need to be charged or replaced. Charge it for a few hours with the device turned off. If that does not work you should try replacing the battery.
Screen brightness is all the way down
The screen brightness might be so low that the screen is hard to read in bright light. Try bringing the device into a dark room to check if the screen can be read. If the brightness is down, turn it up before bringing the device back into a well lit room.
Power button is stuck
Try pushing the button multiple times to release it. Once it is free, hold down the button to turn on the device.
Battery Dies Quickly
The battery dies quickly after being fully charged
Temperature is too cold
Make sure to operate the device in room temperature. Cold temperatures will drain the battery quickly or cause the device to turn off completely.
Battery is old and worn out
After years of being recharged the battery may not be able to hold a full charge anymore. This will reduce the amount of time that the device may be used for. If this is the case the battery must be replaced.
Screen brightness is too high
If the screen brightness is turned all the way up, the battery will drain much faster. Try turning the brightness down or enabling the auto-brightness setting
Camera Not Working
The correct pictures cannot be taken
Camera lens is blocked, cracked, or dirty
Inspect the camera lenses on both sides on the device. Make sure that they are intact and free of any obstructions. Clean them if they are dirty.
The wrong lens view is being used
Make sure that the correct camera is being used. Try changing the camera view to see if the wrong one was selected.
Tablet Not Charging
The device is not charging when it is plugged into the wall
Cord is not plugged in all the way
Make sure that the cord is securely plugged into the device and the wall. If they are not completely connected, the device will not charge.
Power at the outlet
Check to make sure that you have power at the outlet.
Charging port is dirty
Check if the port of the port of the device is clean. If not then the charging cable may not be getting a clean connection. Try blowing some compressed air into the port to get rid of any foreign particles.
Faulty Battery
Touch Screen/Buttons Not Responsive
The device does not respond when the screen is touched or a button is pressed
Surface is dirty
Look to see if the touch screen is clean. If it is too dirty then the touch sensors may not be recognizing the user's finger. Wipe the screen with alcohol pads or a clean damp cloth to ensure a clean surface.
User's hands are dirty/wet
If the user's hand are dirty or wet then it may interfere with the touch screen. Make sure to have clean and dry hands before operating this device for optimal performance.
Button is stuck or dirty
If there is dirt or grease in the cracks around the buttons, then they may become sticky and stuck. Spray compressed air in between the cracks and wipe down the buttons to clean them.
Author
with
Eric Megna
333 Reputation
2 Guides authored
10 Comments
tablet is frozen in one screen.
Nori Byrnes - Reply Share
Main screen comes on but can’t get apps to open. It starts and then freezes. Charge is at 90%.
km_popp03 - Reply Share
Screen brightness stuck on 50 and won't adjust
howardward - Reply Share
it wont let me go past the set up option to connect to wifi. and when i try to connect to wifi that i know works it says can’t connect and i can’t get past this
Megan Parsons - Reply Share
My monitor. well when you plug it in the light comes on then five seconds later goes out and it shut off and won't come back on at all
Sheralyn Thebeau - Reply Share
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 21
All Time: 11,051
