Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Clogging
A clogged vacuum still has suction power, but cannot pic up dirt or debris. The airflow may be restricted, but the motor still sounds functional. If clogged, unplug and discontinue use immediately in order to prevent overheating and power failure.
Dirty Filter
A dirty filter may be the cause of your clogging. If you remove the front module of the vacuum and see that the filter is covered in dirt and debris, it is likely the cause of the clogging.
If the filter is dirty or full of debris, clean it by rinsing or using an air compressor to blow out debris. Examine the filter and make sure it is clean. Replace in the module.
Lodged Object
A lodged object may be the cause of your clogging. If you see an object obstructing the intake of dirt from the vacuum, this is likely the cause.
Take apart the module and look for an object causing the obstruction. If such an object exists, remove the object causing the obstruction.
Poor/no suction
The vacuum cannot pick up dirt or debris. The airflow of the vacuum is severely restricted such that it cannot generate suction.
Broken Motor
A broken motor is a very large obstacle to proper suction. You may notice that your motor is broken if when you power the vacuum on, you hear no noise.
Disassemble the vacuum and check to see if the motor is functioning. If the motor is broken, [http://PlaceHolder|replace it].
Dirty Filter
Examine the filter and make sure it is clean. If the filter is dirty or full of debris, clean it by rinsing in a sink or using an air compressor to blow out debris.
Lodged Object
Take apart the module and remove the object causing the obstruction.
Faulty Hose connection
Check all hose connections and ensure that all connections are complete and secure.
Spitting out debris
Instead of taking in dirt and debris, the unit ejects them. The vacuum may take in some debris but reject a portion of it.
Faulty Intake Valve
Check to make sure that the valve on the nozzle of the vacuum is not broken or damaged. If the valve is damaged such that it cannot function properly, [http://PlaceHolder|replace it].
Power failures
''The unit will not turn on, or it turns on, but quickly turns off. '
Power Surge
If there was a power surge while the vacuum was in use, [http://PlaceHolder|replace the relay unit].
Faulty Power Cable
The power cable may be broken. Replace it with another cable to determine if this is the issue.
Overheating
The unit gets too hot when in use.
Overuse
The vacuum may overheat from overuse. Unplug it and wait 15-20 minutes allowing the device to cool.
Airflow Issues
The Scorpion Quick Flip relies on airflow through the device for cooling. If the device is clogged, or the dirt cup is full, this may cause the unit to overheat. Unplug the unit and allow it cool, empty the dirt cup and clean the filter.
Faulty Power Cable
The power cable may be broken. [http://PlaceHolder|Replace it] with another cable to determine if this is the issue.
Joseph Warner
201 Reputation
2 Guides authored
IUPUI, Team S1-G1, Wilson Fall 2017 Member of IUPUI, Team S1-G1, Wilson Fall 2017
IUPUI-WILSON-F17S1G1
4 Members
24 Guides authored
14 Comments
What does it mean if you plug it in and it flashes a blue light 3 times in 5 different sections?
Julie Westman - Reply Share
Mine does the same thing! Did u get an answer?
danielalynn09 - Reply Share
I'm having this issue now. Any luck with an answer?
Amber Brooks - Reply Share
How do you fix a power failure?
Turns on but quickly turns off.
Gary H - Reply Share
I also have a power failure problem. turns on but quickly turns off.
Judith Davies - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 56
All Time: 10,125
