Diagnosing appliance issues is a mix of detective work and technical know-how. Here's a guide to start unraveling the mysteries of appliance malfunctions:
  • Identify the Symptom: What's the appliance doing (or not doing)? This is your first clue.
  • Locate the Problem: Is the issue where you think it is, or is it hiding elsewhere in the machine?
  • Uncover Related Issues: Are other parts affected or contributing to the problem?
  • Discover Solutions: What fixes can get your appliance back in action?
Take a dryer, for instance. If it's not drying clothes, the culprit could range from a simple setting misadjustment to more complex issues like a clogged lint filter or a faulty thermostat. Sometimes, the problem is as straightforward as switching the control settings from air to heat drying. Other times, it might lead to deeper questions, like whether the user is familiar with the appliance's operations.
Remember, every appliance has its own operational sequence. Familiarizing yourself with this, often detailed in the use and care manual, is crucial in pinpointing and fixing the issue.
Product Failure
Perform the following steps to diagnose and correct a malfunction.
StepAction
1. Verify the ComplaintAsk yourself more questions about the symptoms. What specific issues are you noticing with your appliance?
2. Check External FactorsEnsure proper installation and correct voltage. Are there any external conditions impacting the product's performance?
3. Inspect for Physical DamageExamine for any internal or external damage. This can range from broken parts to structural issues affecting functionality.
4. Review the ControlsConfirm that the settings are correctly adjusted. Improperly set controls can lead to operational issues.
5. Test the ProductRun the appliance through its cycle, comparing its operation to the sequence outlined in the user manual.
6. Assess Proper FunctioningIf the product operates as expected, make sure all users are informed on correct usage per manufacturer guidelines.
7. Troubleshoot MalfunctionsIf the product is not working correctly, identify the faulty component using diagnostic charts or methods and proceed with the appropriate solution.
General Diagnosis and Correction Procedure
When troubleshooting your appliance, engage your senses to pinpoint the issue. Here's how you can get started:
  • Smell: Notice a burning smell when using your washing machine? This could indicate a failing part that needs attention.
  • Sound: Hear unusual noises from your dishwasher? Pause it and try to locate the source.
To further analyze the problem, a multimeter can be invaluable. Here's a step-by-step approach:
  1. Safety First: Always unplug your appliance before starting. It's also a good idea to first check for blown fuses or tripped circuit breakers.
  2. Voltage Check: Set your multimeter to voltage and check the appliance’s receptacle against its nameplate rating.
  3. Access the Problem Area: Open only the necessary panels to reach the suspected faulty component.
  4. Identify the Fault: With the multimeter set to ohms, isolate and check the component. If it's defective, it's time for a replacement.
  5. Component Replacement: Replace the faulty part with a new, original component. Make sure all wires are reconnected correctly.
  6. Reassemble: Put all panels and screws back in place.
  7. Test Run: Plug in and test your appliance to ensure it's functioning properly.
Follow these steps to confidently tackle appliance issues in your own home.
Measuring Voltage on Appliance Components
To ensure your appliance functions correctly, verifying the correct voltage is crucial. Here’s how to measure voltage accurately:
  1. Safety First: Read and understand your test meter's manufacturer's instructions for safe operation.
  2. Setting Up:
    • Connect the probes to your meter: black probe to the negative/common jack, red probe to the positive.
    • Set the function switch to AC VOLTS.
  3. Selecting the Range:
    • Choose a range above your expected voltage (e.g., use a range above 125 Vac for a standard 120-volt outlet)
    • If unsure, start with the highest range and adjust downward as needed.
  4. Taking the Measurement:
    • Carefully touch the probe tips to the terminals of the appliance part you're testing.
    • For a plug, insert the probes into the outlet slots.
  5. Reading and Understanding the Results:
    • A reading close to your appliance’s rated voltage (usually 120 or 220 volts) means the voltage is correct.
    • Significantly lower readings indicate a potential power supply problem.
  6. Deciding on Action:
    • If the voltage is too low or inconsistent, the problem might be with your electrical supply, not the appliance.
    • Consistently correct voltage readings suggest the appliance itself may have a fault.
By following these steps, you can effectively determine if voltage issues are at the root of your appliance problems.
Measuring Line Voltage in Your Home
Measuring line voltage is a key step in troubleshooting appliances. Here's how to do it safely and effectively:
  1. Setting Up Your Meter:
    • Turn your meter to AC volts.
    • Choose a range just above 120 volts for standard outlets.
  2. Measuring No-Load Voltage:
    • Insert one test lead into each slot of an empty outlet.
    • Be cautious: handle probes by the plastic grips, not the metal part.
    • Expect a reading between 115 and 120 volts for a standard 120-volt outlet.
  3. Testing Under Load:
    • Plug in and turn on your appliance.
    • Measure the voltage in a nearby outlet, using the same steps as no-load testing.
    • Under load, voltage might be slightly lower than the no-load reading.
Note: For appliances rated at 240 volts, set your meter above 240 volts. Voltage drops more than 10% can indicate electrical supply issues, especially at the start of motor-driven appliances like washers or air conditioners.
Testing for Ground and Polarity in Home Electrical Outlets
Ensuring your outlets are properly grounded and have correct polarity is crucial for safety. Here’s how to test them:
Testing for Ground
  1. Check Line Voltage: Ensure the outlet has voltage.
  2. Identify Slots: Receptacles have a longer and a shorter slot. Usually, the longer slot is on the left.
  3. Measure Voltage to Ground: Test the voltage between the short slot and the ground hole (round hole). Line voltage here indicates a grounded receptacle.
  4. No Ground Hole: If there’s no ground hole, test the voltage between the short slot and the cover plate screw.
Testing for Polarity
  1. Check Line Voltage: Ensure there's voltage between the longer and shorter slots.
  2. Test Short Slot to Ground: Confirm line voltage between the short slot and the center screw or ground hole.
  3. Test Long Slot to Ground: There should be no voltage between the longer slot and the center screw or ground hole.
Note: If these tests show incorrect results, the outlet may be wired improperly and should be fixed.
Measuring Resistance in Your Appliances
Measuring resistance (ohms) helps determine if your appliance has an open circuit or a short circuit. Here's a simplified guide:
  1. Understanding Resistance:
    • Infinite resistance indicates an open circuit (no flow of electricity).
    • Some resistance means continuity, with electrical loads present.
    • Zero resistance suggests a direct flow, potentially a short circuit.
  2. Setting Up Your Meter:
    • Attach leads: black to negative, red to positive.
    • Set to OHMS.
    • Choose a range higher than the expected resistance (R × 1, R × 10, etc.).
    • Zero the meter by adjusting the pointer to 0 when the leads touch.
  3. Measuring:
    • Connect leads to the component.
    • Read the measurement, adjusting the range as needed for accurate results.
Matt Zieminski
50,364 Reputation
28 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
7 Comments
Micro no calienta
Rocio Rosales - Reply Share
Dejo de prender
Yaniysayunisa - Reply Share
Que debería hacer para repararlo en casa
speaka da engla
soupamanx - Reply Share
Fallo en las teclas del micro
Jorge Luis - Reply Share
Past 24 Hours: 6
Past 7 Days: 81
Past 30 Days: 407
All Time: 8,917
