Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Battery is Not Charging
Battery will not charge or hold a charge.
Old Battery
After a while the battery starts to deteriorate and loses its ability to hold a charge. You will need to purchase a new battery if it is old. Proceed to back of instructions manual to find the correct battery for unit then go to www.DeWalt.com to purchase new battery.
Defective Battery Charger
The charger may not be working due to broken parts or wear and tear. If this is the problem replace battery charger. Proceed to back of instructions manual to find the correct battery charger for unit then go to www.DeWalt.com to purchase new battery charger.
Charger is not Plugged in
Proceed to find an outlet and plug the charger in if the charge does not light up with the battery securely placed on charged first try using a different outlet. If the charger continues to not work purchase a replacement battery charger. Proceed to back of instructions manual to find the correct battery charger for unit then go to www.DeWalt.com to purchase new battery charger.
Drill Will Not Power On
The drill shows no response when pressure is applied to trigger.
Low/Dead Battery
Your battery may be low or out of power. If the battery is low on power the drill may work slowly or not at all. Place battery on charger.
Faulty Battery
Make sure the charger is properly charging the battery and plugged in. If the battery continues to not work please proceed to replace battery. Proceed to back of instructions manual to find the correct battery for unit then go to www.DeWalt.com to purchase new battery.
Faulty Charger
Make sure charger is plugged in and battery is securely pressed in to blades on charger. The red light should be flashing. If the problem continues replace battery charger. Proceed to back of instructions manual to find the correct battery charger for unit then go to www.DeWalt.com to purchase new battery charger.
Drill Bit Falling Out of the Chuck
Drill bits are not staying in the chuck.
Bits are not properly secured into the chuck
To ensure the bits are properly secured into the chuck, follow these steps:
1. Disconnect battery from the drill.
2. Grasp the black sleeve surrounding the chuck with one hand and secure the tool with the other hand. Rotate the chuck sleeve counterclockwise to open the chuck.
3. Insert the drill bit about 1/2” into the opening on the chuck. Secure the bit by rotating the sleeve in the clockwise direction with one hand and holding the drill in the other.
4. To release the drill bit, repeat steps 1 and 2.
Drill Does Not Spin
The chuck does not spin when trigger is pulled
Faulty Trigger/Switch
Make sure that the actuator (forward/reverse button) is completely pushed to either the forward rotation or reverse rotation position. If the trigger still cannot be pulled then a mechanical failure within the trigger may have occurred and a replacement switch will be required. If the trigger does pull but the motor does not power on then the switch may be faulty. To determine if the switch is faulty you will need to open up the drill casing..
Faulty Transmission
If the motor is powering but the chuck is not spinning then a transmission problem is occurring. Slow spinning or no spin is a sign that the gears within the gear box may not have properly seated. Check to make sure that the gear box is not in-between gears and is completely transitioned to the desired gear. If it still does not spin, then the transmission may be faulty and a replacement will be required.
Faulty Motor
A faulty motor can result in the chuck having no spin or slow spin. The motor becoming faulty can be caused by overloading the motor or the brushes within the motor wearing out. In either case the motor will need to be replaced by a new one. Use this guide to see how to remove and replace a motor within the drill.
Drill Spins Slowly
If the drill is working slowly.
Faulty Battery
Make sure the battery is connected and push the battery until it is clicked to the drill. Make sure the battery that it is fully charged. If you not sure the battery is charge, try it with a new battery.
Faulty Motor
It the battery is good, it could be a bad in motor. The motor is what the drill makes spin. If the motor is broke, you need to replace a motor. Here is a guide to change the motor Motor Replacement
Faulty Transmission
Author
with
Brittany
705 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 50
All Time: 2,693
