Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The Laptop Isn't Powering On
The laptop isn't showing any signs of life.
Faulty Power Adapter
Ensure the charger is working by testing it on a working laptop and see if its charging. If it's not charging then the power adapter is at fault.
The Battery Is Not Connected Properly
Ensure the battery is connected to the motherboard as it could get disconnected from movement. If it shows signs of a swollen battery, immediately replace it.
RAM Installed Improperly
Make sure the RAM was installed properly. Sometimes during the installation process, the amount of pressure that was used to install the RAM may not be enough.
The Laptop Overheats
The laptop has cooling problems and is heating a lot.
Faulty Fans
Your fans could've possible had some type of failure that made them stop working which means it won't be able to cool down the laptop to save temperatures. It's recommended that you replace the fans.
Dust in the Vents
The vents outside the laptop could have too much dust inside, preventing them from pushing out the hot air. This obstructs the cooling system. It is recommended to deep clean the vents or spray the dust out the vents with air once in a while.
Thermal Paste Troubles
Thermal paste is a huge essential but overtime it degrades, drys out, and more, so once in a while its recommended to replace the thermal.
The Battery Depletes Fast
The laptops battery doesn't last long
Faulty Battery
As time goes on, the battery's health starts to deplete, which means that the life of the laptop is shortened. This is a simple fix as all you need to do is replace the battery with a new one.
The Screen is Cracked or Damaged
The laptop's screen has visible lines, patterns, or back spots.
Broken Screen
When you have a broken screen, there isn't much you can do. You would need to replace the screen with a brand new one.
No Audio
The laptop's audio isn't outputting anything from speakers or headphones
Speakers Inside the Laptop Are Faulty
The speakers inside the laptop can become worn out or damaged due to various reason such as water seeping into the laptop's speaker or overusing it at high volumes. In such cases you would need to replace them with new ones.
The Speaker Was Disconnected
This is a simple fix; all you need to do is open the laptop, locate the speakers, disconnect the cable, and then reconnect it.
2 Comments
the hinge is breaking too much
Abeloo Aki - Reply Share
Laptop screen repair
Shakila Ahsan - Reply Share
