Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Black Screen
Laptop will boot up and produce sound but no screen display ( See screen replacement guide)
Computer is Frozen
Sometimes all devices need a restart to function properly again. The Dell Vostro 1400 can be rebooted by holding down Ctrl + F11.
Graphics Processing Unit (GPU) is Defective
The GPU can be overheating and causing it to fail. Replacing this part with a new one could fix the display issues.
Motherboard is Faulty
If the motherboard is the culprit of the black screen, the best way to fix it is to replace the motherboard. (See speaker replacement guide)
Faulty Speakers
There is no sound coming from the speakers when I try and play music or a video
Speakers Are Off
Be sure to check and make sure the mute button is not on your speakers. Or make sure the volume is turned up completely on your computer. You can check this by locating the sound or volume settings.
Defective Hardware
Running a diagnostics tests will tell you if there is a problem with the computer's hardware. You can run a diagnostic test by holding down F12 and then selecting “Diagnostic.”
Hard Drive Corrupted
Hard drive device is loud, computer seems slower than usual, random files keep getting deleted without warning.
Restart the Laptop
Turn your laptop off and turn it back on.
Remove the Battery
Remove the battery and then place it back in your laptop
Remove the Hard Drive
Remove the hard drive and then place it back in you laptop
Remove the Battery and Hard Drive
Remove both the Battery and the Hard Drive and then place them back in your laptop
Reboot the Device
The device may need to be reset in order to function properly again. You can reset the Vostro 1400 by holding down Ctrl F11
Corrupted Hard Drive
The hard drive may be too corrupted for you to fix without the proper software or professional help. Detailed instructions on how to replace or repair a corrupted device can be found in the following links
Battery wont charge laptop
The battery is not detected on laptop and wont charge laptop
Remove the Battery
Remove the battery and place back into laptop
Make sure A/C adapter is plugged in
Unplug and and reattach A/C adapter
Make sure outlet is functional
Test your outlet to make sure your A/C adapter is getting charge
Check to see if your charger is plugged in
Unplug your charger from your laptop and then plug it back in fully
No more memory space
Laptop has run out of memory space
Check your memory space
Go to settings then to storage to see how much memory is on your laptop
Esai Gonzales
13 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 33
All Time: 2,495
