Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The Laptop Will Not Turn On
The Laptop shows no sign of powering on.
Battery is Drained
There is no charge in the battery of the laptop. All you need to do is take the cord and plug into the circular port in the right-hand side of the laptop. Make sure the other end of the cord is plugged into a working outlet.
Power Button Failure
If your laptop is receiving charge, but the power button doesn't light up, you may have a broken power button. If that is the case, you need to replace it.
Power Circuit Has Too Much Static Built Up
The laptop has too much static built up in the Power Circuit. Unplug the A/C adapter and remove the Battery. Afterwards hold the power button for 30 seconds. Put the battery back in and try turning the computer back on.
Display Problems
The laptop turns on, but all that is displayed is a ribbon of colors, or the screen is completely black.
Ribbon Disconnect
There is a ribbon of wires connected to the screen of the computer, and the back of the monitor that could be disconnected. This ribbon produces the display on the screen. If it is disconnected, you could reconnected it. If not, you can also clean the ribbon by removing any dust. You can do this by blowing air onto the ribbon, or taking a cue tip and with a little bit alcohol and gently rubbing the cue tip on the ribbon.
Graphics Card Failure
The Graphics Card is the what displays images on your computer. A corrupted graphics card could produce the random ribbons of colors. If there was a short in the graphics card, that could produce the lack of anything on the screen. The first thing you can do is try rebooting the graphics card. If that does not work, you will have to replace the graphics card.
Motherboard Failure
There might have been a short within the motherboard. This is could be caused by many factors, but regardless of how it came to be, the motherboard does not work anymore. If this is the case, the motherboard needs to be replaced. Note that this is a last resort, as motherboards are really expensive.
Video or Audio Files are Distorted
Videos stop playing or listening to audio stops working.
There could have been a short in the graphics card that makes the display distorted. You can try rebooting the graphics card. If that does not work, you may have to replace the graphics card.
Unexpected Shutdown
The laptop unexpectedly shuts down or restarts.
There is a Virus
It is possible that a website that you had visited, or a flash drive that you have plugged in, contained a virus that got downloaded onto the computer. The first thing to do is run a virus scan. If don't have a virus scan, but using an operation system of windows 7 or higher, you can use a built in virus scan.
Overheating
The motherboard can overheat due to the fan not working, or in need of cleaning. If cleaning the fan of dust and lint does not work, then you may have to replace the fan.
Unable to Charge
The laptop is plugged in, but refuses to charge. This could be due to several factors.
Broken Power Cord
The power cord may have a bad connection due to frayed wires. If this is the case, you just need to get a new cord.
Broken A/C Adapter
The A/C adapter could have gone bad. In that case, you need to get a new adapter.
Broken Charging Port
If the power cable works, but the laptop refuses to charge, it could be a bad charging port. If that is the case, you will need to replace the charging port.
Author
with
Madison Chaney
399 Reputation
2 Guides authored
3 Comments
My Dell 1558 stopped working after I changed 3v CMOS . When I press power button a light blinks and that is all. If I turn on an adapter, there will be no light at all. No power in all cases.
The reasons are not covered above
Rafael Yanushevsky - Reply Share
dell 1558 laptop not projecting to second screen via hdmi cable
Patrick Van Loggerenberg - Reply Share
How to replace
Ramadhan Madegree - Reply Share
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 18
All Time: 2,889
