Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Audio Not Working
You have trouble listening to sounds on your computer.
Loose Headphone Jack
Test audio through the computer speakers, then test it using headphones. If the audio is only distorted while listening via headphones, the audio jack or the headphones themselves may be faulty. Audio that cuts in and out is often a sign of a loose audio jack, so make sure the audio jack is fully inserted in the computer.
Faulty Driver
If the audio sound is distorted when listening through the laptop’s speakers, the audio driver may be corrupt. If you are running XP as your system, then you will need to install the Sigmatel audio driver. This audio driver will not install until you first have a chipset driver installed. Once you download and install these in order, with restarts after each, you will be set. Here is the link to the page with links for the Sigmatel audio Driver and intel mobile chipset driver. https://www.dell.com/community/Laptops-G...
Black Or White Screen
Your Dell Latitude D830 will not show any information on screen.
Broken Motherboard
If your Dell Latitude D830 is not showing any information on screen display, then you may have a problem with the motherboard. This will need to be checked once you disassemble the laptop. To check this you will need a multimeter and a electronic schematic diagram. If you find it is the motherboard, and the multimeter determines it has faulty components, then these components should be replaced.
Power Button Fails To Work
If your Dell Latitude D830 is not showing as being turned on you may have a problem with the power button. Check this by using charger to see if the charging light works. Disassemble the power button and check the continuity of the circuit with multimeter. If the circuit still has electrical current then the power button needs to be replaced.
Power Circuit Is In The Wrong State
If your Dell Latitude D830 screen is not showing anything when the power button is pressed then your power circuit may be in the wrong state. To reset this circuit unplug the charger, take out the battery, and hold down the power button for 30 seconds.
Computer Keeps Dying
Computer Is Not Holding A Charge
Your battery may be at fault here. This could be due to “overcharging” or even just an old battery that has lost the properties used to hold a charge. For this you should proceed to our Battery Replacement Guide here [Battery replacement guide right here].
Keys Don’t Work
When you type all or just particular keys don’t work.
One Or A Few Keys Are Broken
If your Dell Latitude D830 has certain keys that are not working, you can take a knife or any sturdy but thin object to gently pry the cover piece off. Once it is off, can take a cotton swab with a little bit of alcohol to clean out the inner workings. After that you can take compressed air to blow out any crumbs or larger pieces of junk that you were not able to get out first.
None Of The Keys Work
If none of your Dell Latitude D830 keys are working then the problem may not be a specific key, but the whole keyboard in fact. You should then refer to our Keyboard replacement guide here [Keyboard replacement guide goes here].
Video Not Working
You have trouble playing videos from a cable hooked from the laptop to the desktop.
NVIDIA Chip Is Failing
If your Dell Latitude has no video signal to the LCD, but external monitor works fine. It's not just a backlight issue. There's no image at all. Toggling between CRT/LCD is same. The CRT stays on, nothing on the LCD.
You will likely need to get a new system board.This is a NVIDIA chip on the system board and this chip has likely failed. A board with integrated graphics should fix the problem and have you running again.
Author
with
Nick Long
207 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 17
All Time: 2,073
