Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Performance is sluggish
The computer takes a long time to boot or responds slowly to commands.
Computer is infected with malware
If there are no hardware issues, malware could be slowing your computer down. Run a comprehensive scan on your computer using an anti-malware program, such as Windows Defender or McAfee.
Insufficient RAM
If your computer crashes, freezes often, or reboots randomly, consider upgrading the computer’s RAM.
CMOS Battery Failure
If your computer runs slow, the date and time is constantly resetting every boot, or you're receiving "Booting Error" messages, you may need to replace the coin cell battery (CMOS). Use this guide to replace the CMOS.
Keyboard key is non-operational or missing
One or more keys are not typing the correct symbol/not typing symbols, getting stuck, or is missing a key entirely.
Device is set to the wrong language setting
Check the language setting and see if you have the correct language that you use on. The wrong language may cause keys not to type the correct symbol or to type different symbols than what is shown on the key.
Key is stuck
Dirt, dust, or other debris could be stuck under the key, preventing proper keystrokes. First use a can of air to blow out any debris beneath the affected key(s). If this does not work, remove the key and clean underneath, then reinstall the key back into its housing.
Missing or broken key
If keys are missing or broken, replace them using this guide.
Device can't run off battery power, or won't charge at all
The computer struggles to hold a charge, or will not charge at all.
Faulty battery
If the computer only turns on when connected to the charger, the battery is old or no longer operational. Replacement may be necessary.
Faulty charging port
Ensure the charger is firmly plugged into the charging port, then check that the adapter's light is illuminated. If the light fails to turn on, the charger may be damaged, and replacement may be necessary.
Computer is overheating
The computer is running abnormally hot and shuts down automatically, or experiences reduced performance.
Airflow is restricted
Confirm the fans are functional by observing the blades spinning; if the fans aren't running during operation, move on to the next possible solution. If the fans are functional, inspect the blades for dirt/debris buildup, and clean as necessary.
If the fans aren't operational, the fan may need to be replaced.
Corrupted files
Some of the computer’s files or programs will not open.
Software incompatibility
Run the compatibility troubleshooter on your computer and update the software.
Hard drive error
If your computer displays a blue screen, reboots suddenly, or crashes when opening files, the hard drive may be corrupted. Replace the hard drive.
Faulty SSD
If the computer is unable to read files, runs too slow, or does not boot, you may need to replace the solid state drive (SSD).
1 Comment
The RAM in this laptop is soldered to the motherboard so it's not possible to upgrade it.
Jack Pendleton - Reply Share
