Student In Progress
This wiki is being worked on by hardworking students.
Dell Latitude 7320 Overheating During Use
Dell Latitude heats up extremely, or the fans run at a very high rpm.
Restricted Air Flow
Using the device on a soft surface could restrict the airflow in and out of the device.
  • If you’re using the device on a bed; have a hard flat surface you can rest the laptop on.
  • Make sure covers or blocks the vents while using the device.
Heavy Workload
Running multiple or a very demanding application can overwork the laptop, resulting in an increase in temperature.
  • Limit how many applications are open at once.
  • Make sure settings are not demanding more than the laptop can handle.
  • Check task manager and see how many processes you are running if you have too many running that could be the cause of the overheating
Dirty Fans
Fans can build up dust from prolonged use, which can lead to inadequate airflow to the internal components.
  • Open the device and, while holding the fan still, use compressed or canned air to blow any dust out from between the blades.
Battery Failure
Your battery may be worn out or damaged causing it to produce more heat than normal.
  • Check and make sure the battery are not visibly bulging. If it is, then it needs immediate replacement. Lithium-ion batteries are incredibly dangerous and should not be included with normal garbage. Take it to a specialized collection site; check your city or county's website to find one near you.
Motherboard Damage
The motherboard is home to many components which leaves more room for failure, which can lead to overheating if something has failed.
  • To check carefully remove the back panel and inspect what you can see for damage.
  • Look for burned, cracked, liquid residue, corrosion, or bend.
  • If you can see any damage the motherboard will have to be replaced refer to this guide to see how its done.
Author
with
Hayden Miller
151 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 24
All Time: 82
