Student In Progress
This wiki is being worked on by hardworking students.
Dell Latitude 5520 Overheating During Use
When not plugged in, the laptop fails to hold a charge for a long duration of time. Follow these steps to help increase your battery life.
Clean Vents and Internal Fans
Clouded or dust-clogged vents and fans cause overheating by blocking airflow and trapping thermal energy around internal components. A layer of dust sitting directly on sensitive electronic components (like a CPU, GPU, or motor) acts as an insulator, holding heat in instead of letting it radiate away. Even a thin layer of dust can significantly drop cooling efficiency.
Next Steps:
  1. Use your laptop on a hard, flat surface like a desk or table. Avoid soft surfaces like beds, pillows, or carpets that block intake vents.
  2. Turn off the laptop, unplug the power adapter, and use a can of compressed air at a 90-degree angle (6 to 8 inches away) to blow duct out of the side and bottom air vents
  3. If dust is heavily packed inside, remove the bottom cover of the Latitude 5520 to clean the fan blades and cooling find with a soft brush of compressed air.
Identifying Background Drain
One of the main reasons why background drain causes overheating is because the Dell Latitude 5520 has a sustained high CPU, or a Central Processing Unit. The Dell Latitude 5520 has a default ‘Windows modern standby’ setting, which allows the computer to run background maintenance tasks and stay connected to a network even if the lid is closed. Because of this, if a background task wakes the CPU inside a backpack or a softer surface with poor air flow, hot air gets trapped inside the system. The laptop’s internal sensors send signals to the fans to spin faster and cool down the system, however since there’s poor airflow, the fans just circulate the hot air around. This cycle makes the laptop excessively hot and drains the battery.
Step 1: Identify
  1. Open the Start Menu and click on Settings
  2. Navigate to System, then click on Power & Battery
  3. Scroll down to the Battery Usage section
  4. Review the app percentage list under the Apps breakdown to find apps consuming a high amount of power while not actively in use.
Step 2: Turn Off and Restrict
Once the problematic apps are identified, restrict its background permissions:
  1. Go to Settings > Apps > Installed apps.
  2. Locate the draining app, click the three dots (...) next to it, select Advance options, and change the Background apps permission dropdown menu to Never
Some high-impact apps may not appear initially under the Apps breakdown, but they still may constantly run in the background once your Dell boots up.
Step 3: Disable Startup Apps.
  1. Press Ctrl + Shift + Esc on your keyboard to open the Task Manager
  2. Click on the Startup apps table
  3. Look at the Startup impact column
  4. Right-click any non-essential application labeled High or Medium and select Disable.
Turn-On Energy Saver/Check Battery Health
Energy Saver
When you use your laptop for a long while, it may cause your laptop to overheat.  To make sure your battery life lasts for a longer time.
Turn the energy saver on your laptop by selecting your quick settings panel.
Once this panel is opened, click on energy saver to turn it on .
Battery Health
  1. Turn on or restart your Dell Latitude 5520.
  2. Press the F12 key repeatedly once the “Dell” logo displays on the screen to access the One Time Boot menu.
  3. Select diagnostics and press enter.
  4. Follow the on-screen instructions and complete the test. Once the test is complete, click ‘Advanced test’ and then select ‘System Info’.
  5. Navigate to the ‘Health’ tab, and review the battery health information to determine if your battery is needing to be replaced.
A Swollen Battery
A common cause for an overheating Dell Latitude 5520 is a swollen battery. To tell if the battery of a Dell Latitude 5520 is swollen, the trackpad may feel stiff, or looks like it’s pushed upward from underneath due to pressure from the expanding battery. If the Dell Latitude 5520 bottom panel is bowed, then this can also be due to the battery expanding. Finally, if the side seams, palm rest, or bottom cover has a visible gap or screws that no longer align flush, those are also strong indicators of a swollen battery.
Zoe W
101 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 45
All Time: 45
