Keyboard slow to respond
The keyboard continues to hesitate and react slowly when typing.
Filter Keys are on
It’s possible that your keyboard’s filter keys are on. Hold down shift for 10 seconds and check if the problem continues.
Update your keyboard Driver (Windows 10)
It’s possible that your keyboard’s driver could be out of date. Go to your Device Manager, and locate the Dell L100. Click update driver, follow the instructions, and check if the problem continues.
Keyboard is not typing assigned keys
The keys being pressed do not match the output on the screen.
Num Lock is on
If some of your letters are coming out as numbers, number lock is on. Press the number lock key on the right keypad to turn it off.
Some letters have foreign accents (Windows 10)
If your computer is receiving letters that are not a part of your preferred language, press the windows key + the I key. Go to time and language, and select your preferred language.
Liquid Spill
If a group of keys are not working on your keyboard, you should clean your keyboard with a damp cloth and use a can of compressed air. Allow your laptop to dry and check if the problem continues.
Stuck or Sticky Keys
The keys on the keyboard are having difficulty moving up and down.
Keys need to be cleaned
Dampen a cloth with warm water. Wipe the keys down with the cloth, and check if the problem continues. If the keys are still sticky, you can remove the individual stuck or sticky key caps following the remove keycaps guides.
Certain Programs are not working with keyboard
Some programs, like Microsoft office, may have difficulty with your keyboard.
Update the Program
Make sure that you are using the most current version of the software you are using.
Addison
3,165 Reputation
17 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 43
All Time: 1,419
