Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Computer will not turn on
The laptop will not respond or show any sign of powering up.
Turn the computer on and ensure that all parts are receiving power. Check that all cables are connected properly and are not frayed/damaged. Check that all ports/connectors are not damaged
Keys are not responsive
The keys are resistant when pressed or do not feel natural when pressed down on.
There may be something stuck under the key. Use a compressed air duster to try to dislodge any physical material from under the key. If the air duster does not work, remove key and clean under it then snap the key back in place.
Keys are not responding on the OS screen
The keys may be physically pressed, but no action is taking place on the computer screen.
Check if the same issue occurs with an external keyboard. If that does not work, try the onscreen keyboard, then boot it in safe mode and try again. The issues may be due to a connected external keyboard/mouse that has been left on and in a position that has its keys being constantly pressed. Turn off your Bluetooth in the settings panel to see of this is the issue.
Computer Won’t Boot
Computer will not turn on or crashes during the boot up.
Ram Issues:
If you hear 2 or 4 beeps when booting up your computer, this signifies an issue with the RAM. It may be insufficient and so you should install new/more RAM to resolve this.
Hard Drive Issues:
The hard drive may be damaged from incorrectly shutting down the computer. To resolve this, you can use a windows DVD for the version you have and choose the “repair your computer” option and let it run by clicking “startup repair”.
Computer is getting very hot
Buildup in air vent
There may be too much dust/build up on the air vents preventing cooling for the computer hardware. Use a compressed air duster to clear the blockage.
Not enough/worn out thermal paste
Apply a new strip of thermal paste over the original area.
The Display is Not Working
The display is not turning on or there are issues with parts of the screen or color issues.
Use the LCD Built in Self-test (BIST) to determine whether this is an issue with the LCD. If the LCD is the problem, then have the LCD be replaced. The test will run a series of different colors and words on the screen. If the problem does not show up during the test, then the problem is not an issue with the LCD. To start the test, turn on/restart your computer. Press <F12>. Select Diagnostics and press Enter. If there are no colored lines on the screen press <N> to enter the LCD BIST
Issue is unidentifiable and may have to do with faulty hardware
The laptop is not functioning properly, and previous basic troubleshooting steps have not resolved the issue.
Use the built in Pre-Boot System Assessment (PSA) to identify the problem. To run PSA diagnostics press <F12> to open up the Boot Menu. Select Diagnostics and press Enter. Follow instructions on the screen. If a component fails the test, an error code will appear. Search for solutions using your error code at dell.com/support . If there are no problems with your device the message, “No problems have been found with this system so far. Do you want to run the remaining memory tests? This will take about 30 minutes or more. Do you want
to continue? (Recommended).” Will appear.
If you have memory issues, press <y> if not press <n> to complete the test
Muhammad Erchid
1,108 Reputation
5 Guides authored
USF Tampa, Team S1-G6, Leahy Fall 2018 Member of USF Tampa, Team S1-G6, Leahy Fall 2018
USFT-LEAHY-F18S1G6
3 Members
60 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 14
All Time: 392
