Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Touchpad Failure
The touchpad isn’t working or responding correctly.
Touchpad is Dirty
Carefully clean the touchpad with a bleach wipe so it can respond to your finger correctly.
Touchpad is Off
Go to Control Panel and select Hardware and Sound
Select Devices and Printers and right click the device icon
Select mouse settings
Switch to the Touchpad feature named by manufacturer (ex. ELAN) and click enable device
Try restarting your laptop if the touchpad still isn’t working and if it’s not after startup, refer to this guide for more details
Computer Shutting Down While in Use
The laptop shuts off unexpectedly during usage.
Updating your BIOS
If running BIOS 1.5.3, you can update to 1.6.0 using this guide and boot it to BIOS setting, Afterwards select Restore Setting and then BIOS Default to resolve this issue.
Keyboard Failure
Keyboard slowly starts to malfunction and stops working.
Keyboard
To troubleshoot your keyboard follow these steps:
1. Restart your device
2. Attempt to use your keyboard
3. Make sure your keyboard isn't locked
4. If keyboard still doesn't work refer to this guide for help
Computer fails to start
When you start up your computer it will not start at all or if the lights and fans refuse to start
Beep Code Troubleshooting
When you restart your computer listen for a series of beeps when it is restarting and refer to this guide and go to 11 and refer to table 1.
Occasionally there is no beep follow this steps to troubleshoot:
1. Disconnect all external peripherals and all external storage devices
2. Remove the AC adapter and unplug the adapter from the wall
3. Ensure all AC adapter connections are tight and replug the charger in
4. Restart your computer to see if it stops again
5. If so refer to this guide for help
Unresponsive Touchscreen
The touchscreen does not respond to user input
Dirty Touchscreen
Ensure the device is off. Using a clean microfiber cloth, gently wipe off any dust, smudges, oil, or debris from the LCD display. Wipe in a circular motion. Do not use any sort of cleaning solution. Any sort of moisture on the screen should be wiped off completely.
Screen Protector
If a screen protector has been installed on the device, the device may not be able to register touches to the screen. Ensure the device is off. Remove the screen protector and restart the device.
Recalibrate the Touchscreen
If the touchscreen is not responding calibrating the screen may solve the issue.
1. In the search box type “calibrate”
2. Select “calibrate the screen for pen or touch input”
3. Select the calibrate button
4. Follow the onscreen instructions
5. Save the calibration data
6. Restart the device
If none of the the above work, click here for a guide on the Dell diagnostics tool for the LCD display.
Decreased Battery Life
The amount of time the device runs on a full charge is noticeably decreasing.
Check Battery Health
Ensure that the battery is in good condition. There are various diagnostic tools by both Dell and Microsoft to assist you. Click here to view a guide of various diagnostic tools. If your battery is healthy, there is likely another issue related to the battery life.
AC Adapter Functionality
Verify that the battery is being charged correctly by ensuring the AC adapter is recognized by the device. To do so:
1. Restart the device
2. Press the “F2” when the Dell logo appears on the screen
3. Check the “AC Adapter Type” in the BIOS options
a. If the type is none, ensure that the adapter is connected
b. If the type is unknown, further troubleshooting is required. View this guide for more information
Author
with
Jalon Walbridge
63 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 926
