Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Laptop Will Not Turn On
The laptop shows no signs of powering up.
Faulty Power Adapter
Check if the power adapter is plugged in and the charge light is on. If the adapter is plugged in and the light is not on, the adapter may not be working properly and a replacement adapter should be considered.
Faulty Battery
If the laptop only powers up with the power adapter plugged in, the battery may not be working properly. A replacement battery should be considered.
Display Is Off Or Distorted
The laptop display is black, discolored or flickers.
Backlight is Off or Broken
Check if the backlight is off. If it is on and the images on-screen are faint, the backlight may be broken and in need of replacement.
Screen is Broken
If the screen is completely black or white with colored lines, it may be broken and in need of replacement. Try plugging the laptop into an exterior monitor to see if the motherboard is still working. If an image is displayed, then just the laptop display needs to be replaced.
Motherboard Issue
If the screen flickers or has unresponsive pixels, it may have an issue with the motherboard. The cable connecting the display to the motherboard could be loose or damaged, or the graphics chipset on the motherboard may have an issue. Follow the guide for accessing the motherboard to check for these problems.
Keyboard Is Not Responding
The keyboard is not responding or working properly.
Disconnected Keyboard Cable
Check if the cable under the keyboard is properly connected. If not, reconnect it. If the keyboard still does not work, replacement may be required.
Trackpad Is Unresponsive
The trackpad is not responding to my touch.
Buildup of Dirt or Contaminant
If the touchpad is dirty, an accumulation of dirt could be causing the touchpad to be unresponsive. Turn off the laptop and clean on and around the trackpad with an ammonia-based or screen cleaner.
Touchpad Disabled
The touchpad may have been accidentally disabled. On the laptop, navigate to "Device Manager" and click on "Mouse and other pointing devices". Find the "Dell touchpad" and ensure the touchpad is enabled.
Laptop Is Overheating
The laptop is overheating and shutting down.
Laptop Ventilation is Blocked
The laptop vent is on the bottom of the device. Using the laptop on a bed or similar surface can cause the laptop to overheat. Make sure to use an appropriate surface or consider buying a laptop cooling pad.
Dusty Air Vent
If the laptop is overheating, it may be due to a dusty air vent blocking airflow. Using a clean toothbrush, brush the air vent until the dust has disappeared.
CD Disk Tray Malfunctioning
The disk tray is not reading discs.
Dirty Disk Tray
Dirt or other foreign substances may be causing read errors. Open the tray and blow compressed air onto the tray. Dampen a cotton swab with rubbing alcohol and clean the dirty area. Dry the tray with a fresh cotton swab. The tray should be completely dry before use.
Disc Error
Before inserting a disc, check if it is dirty. If dirty, clean with a damp cotton cloth, wiping with straight strokes from the center to the outside rim. After cleaning with the damp cloth, use a dry cotton cloth to dry disc using the same strokes.
Kody Dahlke
742 Reputation
5 Guides authored
USF Tampa, Team S1-G5, Leahy Spring 2018 Member of USF Tampa, Team S1-G5, Leahy Spring 2018
USFT-LEAHY-S18S1G5
5 Members
60 Guides authored
1 Comment
Sonic Computers - Reply Share
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 29
All Time: 761
