Student In Progress
This wiki is being worked on by hardworking students.
Dell Inspiron 14 3420 Over heating
An over heated laptop can lead to several operational glitches like random freezes and shut downs. Below is several trouble shooting measures to correct any issues. If trouble shooting fails, below are recommendations for component replacements like the CPU, battery, and the vent.
Hot environment
If you are in a hot area or in direct sunlight, your computer might overheat. If you think this is the cause, try to move to a cooler area or in the shade. Stay there for about 20 minutes, giving your computer a chance to cool down and try to turn it on again.
Heavy Workload
Using your computer while having too many tabs or applications open may cause your computer to overheat. Try to close unnecessary tabs or applications and give your computer a chance to cool down before you continue working.
Using your computer as it's plugged in When charging your computer your battery is already having stress on it, making it hot. If you're running your computer while it is charging, it is adding extra stress to the battery, making it more likely to overheat.
Computer not in energy-saving mode
Try putting your computer in energy saving mode. This gives your computer a chance to not work as hard, and it may cool down.
Defective Battery
If the above Troubleshooting measures fail to resolve the issue, then your battery may be defective. Follow the related guide and its steps for replacement.
Poor CPU Cooling
If the above Troubleshooting measures fail to resolve the issue, then your CPU's cooling system may be failing. Follow the related guide and its steps for replacement.
Dusty Internals and/or blocked Vents
If the above Troubleshooting measures fail to resolve the issue, check to see if your internal components are dusty and check to see if the computer's dedicated vents are blocked. Follow the related guide and its steps for repair.
Lily Campbell
101 Reputation
0 Guides authored
UMass Dartmouth, Team 3-3, Botvin Fall 2026 Member of UMass Dartmouth, Team 3-3, Botvin Fall 2026
UMASSD-BOTVIN-F26S3G3
3 Members
0 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 31
All Time: 31
