Student In Progress
This wiki is being worked on by hardworking students.
Dell Chromebook 3400 Does Not Charge
Is your Dell Chromebook 3400 not charging? There are several possible reasons why your device may not be charging. Common causes include a faulty power adapter, a clogged or damaged charging port, battery issues, or outdated software. Follow the troubleshooting steps below to identify and potentially resolve or diagnosis the problem.
Faulty power adapter
A faulty power adapter is one of the most common reasons a Chromebook may not charge.
Check the power adapter: Inspecting the charger and its cable for visible damage or loose connections.
Try another power adapter: If possible, use another compatible Dell Chromebook charger to rule out the issue of it being the charger.
Check the outlet: Plug another charger into the outlet to make sure the outlet is working.
If another compatible charger works, the original power adapter may need to be replaced.
Charging Port
Dust, dirt, and other debris can collect inside the charging port, clogging the port and prevent the charger from connecting properly.
Remove debris: If the port is clogged, carefully remove any loose debris using a cleaning tool. Avoid forcing anything into the port.
Check the connection: Plugging the charger back in, confirming it's going all the way in. Along with looking for damage to the cord testing If the charging cable feels loose or only works at certain angles, the charging port may be damaged.
If cleaning the port does not resolve the issue, it may require professional inspection or repair.
Battery Issue
If the power adapter and charging port are working correctly, the battery may be the cause of the problem.
Restart the Chromebook: Disconnect the charger, restart the device if possible, and reconnect the charger.
Allow time to charge: Leave the Chromebook connected to its charger for approximately 30 minutes before attempting to turn it on.
Check battery condition: If the Chromebook only works while connected to the charger or shuts down immediately after unplugging it, the battery may be failing.
How to check for updates:
  1. Turn on your Chromebook and connect it to Wi-Fi.
  2. Click the time in the bottom-right corner of the screen.
  3. Select the Settings gear icon.
  4. Select About ChromeOS from the left-hand menu.
  5. Click Check for updates.
  6. If an update is available, allow it to download and install.
  7. Restart the Chromebook if prompted.
If following these basic troubleshooting steps does not work to identify why the Chromebook is not charging and the issue continues, internal components may need to be replaced.
Nyle Barros
101 Reputation
0 Guides authored
UMass Dartmouth, Team 3-7, Botvin Fall 2026 Member of UMass Dartmouth, Team 3-7, Botvin Fall 2026
UMASSD-BOTVIN-F26S3G7
3 Members
0 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 53
All Time: 53
