Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Laptop does not start up
Laptop will not turn on, screen stays blank.
Dead Battery
If the laptop is not turning on, it is possible that the battery is dead. Plug the laptop into an outlet using the power adapter. Be sure that the outlet functions properly.
Faulty Charger
Try to run the laptop form the charger only. Plug the laptop into an outlet using the power adapter. Be sure that the outlet functions properly. If this does not work, the charger may be faulty and needs to be replaced.
Slow response times
Computer does respond right away when an application is clicked on.
Background Applications are Using Extensive Memory
Open Task Manager and look towards the column labeled “CPU” and close applications that are taking extensive memory despite not being in use.
Corrupted Hard Drive
Check for corrupted files using Windows File Explorer which will attempt to fix any corrupted files.
Insufficient RAM/unseated RAM
Open the back of the laptop and look for flat sticks, these are your RAM. Check if they are properly seated into their slots. If they are, it may be a case that you need more RAM.
Extensive loading times
Applications and web browser pages take a very long time to load.
Unused Background Applications Running
Background applications can cause the computer to run slowly. Close out any background applications in the task manager by pressing CTRL+ALT+DEL, choose the application that is not being used and end the program. If this does not work, try updating and restart the computer.
Malware Infection
It is possible that the laptop has a malware infection that could be causing issues. Run Windows Defender to detect any potential issues and follow the prompts to remove the malware.
Insufficient RAM
If all else fails, this computer may have insufficient RAM to run the desired application. Using tools, open the bottom of the laptop and look for flat sticks, these are your RAM. Check if they are properly seated into their slots. If they are, it may be a case that you need more RAM.
Not connecting wirelessly
Computer won’t connect to wireless devices.
Credentials don’t Match
Re-enter credentials such as username and password again and make sure they are correct.
Router Issues
Router may simply need to be restarted. Unplug the power cord from the outlet, wait 10 seconds, and plug back in to restart it.
Replace Internet card
Inside the laptop there is an actual internet card that allows the laptop to connect to the wirelessly. It may be the case that this needs to be replaced by opening the laptop and changing it out with a new one.
Laptop randomly shuts down
Computer turns off without being prompted and without warning.
Damaged Battery
If the laptop does not charge, overheats or if you open up the laptop where the battery is may be swollen due to a buildup of gas and heat.
Faulty Battery
If the battery is damaged or faulty in any way, it will need to be replaced by purchasing a new one that is compatible with your device.
Fan is Overheating
Open the laptop and check if the fan is covered in dust. If so, clean it using a compressed air can and spray around the fan until the dust is gone. Water will cause damage to the laptop.
Display Won’t Power Up
Display won’t turn on, but battery charge still illuminates.
Display Malfunctioning
If the computer has not been restarted recently, this may cause the display to malfunction. Click on the Start menu, under Power choose Restart.
Dead Battery
If the display is not turning on, it is possible that the battery is dead. Plug the laptop into an outlet using the power adapter. Be sure that the outlet functions properly.
RAM Sticks need to be Inspected
Using tools, open the bottom of the laptop and find the blue or green flat sticks. Open the back of the laptop and look for flat sticks, these are your RAM. Check if they are properly seated into their slots, adjust if needed.
Fan Running Loud
Fan is excessively loud, more than usual.
Fan is Dirty
Remove the top of the keyboard so the motherboard and other components are showing, and locate the fan and spray compressed air to remove the dust. Do not apply to much air to the fan so there is no further damage around the area.  https://tinyurl.com/bxr38uh9
Faulty Fan
Remove the top of the keyboard and locate the fan, remove the screws, and wire harness from the mother board and mount the new fan and screw in no plug into the motherboard.
Incorrect Fan Speeds
Locate a driver's webpage for the chipset in computer and download one that is safe. Once this is done you can change the speed of the fan so it can keep the CPU under a certain temperature. While downloading drivers, use trusted sources because downloading wrong ones could cause viruses.
Author
with
Marina Vozzella
539 Reputation
4 Guides authored
UMass Dartmouth, Team 3-7, Sinclaire Fall 2021 Member of UMass Dartmouth, Team 3-7, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G7
3 Members
72 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 5
Past 30 Days: 14
All Time: 412
