Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Trigger Not Working
Pulling the trigger does not run the drill
Trigger is jammed
Trigger cannot be pushed in and the lock is in the off position. If the trigger is jammed the drill will have to be opened so that the obstruction can be removed.
Trigger is too loose
Trigger is fully compressed but the motor does not run. The trigger may also not fully recoil upon releasing it. If the trigger is loose then the drill can be opened up and it can easily be tightened.
Trigger has broken apart
A rattling can be heard when the drill is shook. Pressing the trigger in does nothing.
Motor not running
Trigger appears to be functioning but the motor is not running.
Motor has disconnected from trigger
There will most likely be a connection tab disconnected from the trigger. Taking apart the drill and reattaching this tab should fix this issue.
Motor has died
A replacement motor is needed to be bought.
Battery not charging
Battery does not retain a charge when place on the charger for an extended period of time.
Battery to charging connection is incomplete.
If the battery is not fully connecting to the charger it will not charge. Check to make sure that the battery is clipped in. If it is fully pressed in then the issue may be within the battery or the charger.
Charging dock has broken
Before buying a replacement make sure the issue is in the charging dock by connecting the drill to a working charger. If the dock is the problem buy a replacement.
Battery pack needs to be replaced
The battery pack may not be retaining a charge which means a new battery is required. Issue can be distinguished if the drill works while connected to using a cord.
Rotation switch is not working
Flipping the switch is either not possible or does not change the rotational direction of the drill.
Switch is jammed
If the switch is jammed, like the trigger, the drill should be taken apart and the jam can be undone.
Switch has broken apart
The switch may have broken into two or more pieces within the drill. A rattling may be heard when the drill is shaken. By taking apart the drill and removing the broken pieces a new switch can be installed.
Switch is disconnected from motor
If the drill does not switch rotational direction then it is likely slightly shifted within the drill. Opening the drill and readjusting the switch will likely fix this issue.
Lock switch doesn't work
Lock switch either does not release or does not lock in the drill head.
Hinge pin has broken
If the hinge pin has broken then the lock switch may loosen to the point at which it no longer works. A new pin needs to be bought as replacements.
Hinge pin shifted out of position
The hinge pin may have slid out of position. Taking the drill apart and shifting the pin back into place should solve the problem.
Switch won't move
The switch might be stuck on the spring behind it or it may have been slightly shifted within the drill so that is was catching on another piece of the drill. Shifting the switch back into place should solve the issue.
Stephen Rada
433 Reputation
4 Guides authored
4 Comments
My 20v brushless doesn't work when battery is locked. But does just before the battery locks
Kyle Rowland - Reply Share
I’ve put a 54v battery in my Dewalt 580 planer 18v machine, it’s no longer working, does anyone know what’s gone wrong or blown and what’s needed to get fixed
TOTAL FM LTD - Reply Share
Drill won't work when pointed up.
savedjun94 - Reply Share
Motor doesnt turn over but led light turns on normally if I hold trigger and remove battery and reattach it after a few times of sliding battery on and off once motor kicks on it bn will keep spinning until I release trigger…
joeymata19 - Reply Share
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 31
All Time: 16,303
