Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Controller not charging
Wont charge when plugged in
Imperfect contact for power plug
Make sure the plug is all the way in.
The light will turn on if the controller is charging. If the light fails to turn on when the plug is fully plugged in, the adapter is faulty.
To fix the problem the charging port must be replaced.
Wont stay charged for as long as it use to
If the battery for the remote doesn't seem to stay charged as long as it use to, first make sure the battery is fully dead and charge it until the light flashes that it is done.
If battery still seems to not last very long you will need to consider a battery replacement.
Battery dies before getting to 1%
If battery dies before getting down to 1% the battery is weak and can be fixed by replacing the battery.
Controller experiences glitches, lag, or hesitation
Errant behavior during flight
Make sure battery is fully charged
Bring device back home using the home button.
If the GPS check fails. Move away from any major metal objects (cars) and power lines. Try and restart the drone, Controller, and the controlling device.
Ensure that all devices have a strong connection with each other
Drone unresponsive to controller input
My drone is not connecting to the controller
Restart both drone and operating device.
Ensure DJI Go app is up to date.
Connect controller with phone or tablet via USB cord. Make sure both ends are firmly locked in both ends.
Error updating controller
It never reaches 100% updated
Make sure USB cable is fully plugged in. Changing the cable can also be beneficial.
Restart device.
Delete DJI Go app and then re-download app on phone or tablet. If update has failed try and download with DJI Assistant 2.
Plastics break on remote
Antenna breaks/falls off
If the antenna on the remote is loose or has broke off there is a couple of ways that it can be fixed. If the wires are still attached and not damaged you can epoxy the antenna back on or order a antenna repair kit.
Plastic cracks/breaks off
The plastics on your remote maybe be damaged or broken. You can replace the plastics by ordering a plastic kit for the remote.
Author
with
Samuel Kenyon
16 Reputation
0 Guides authored
6 Comments
Replacement controler does not pare with phantom 4
Claude Page - Reply Share
The controller doesnt come on but the four white lights keep blinking after I press once then press and hold. Also it doesn’t indicate that it’s charging
Ahmad Salele - Reply Share
I have the same problem, The controller doesn't turn on, but the four lights keep blinking after press and holding the button
Peter Bennett - Reply Share
Me too. Did you fix it?
Andre ELS - Reply Share
Please e mail me at edtuttle77@gmail.com. The problem I have I can't get it to imu calibration it fails every time. Not only that if I try and start the moters by pulling the sticks to the corners it gives me a attachment that tells me to check my settings in my main controller settings there is nothing conflicting
Ed Tuttle - Reply Share
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 52
All Time: 8,607
