Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Connection Problems
You have trouble connecting your camera to Wi-Fi.
Faulty Adapter
This problem occurs when the camera is unable to pick up the WiFi signal. The probable cause for this problem could be a faulty Wi-Fi adapter within the camera.
Weak Signal
A weak signal where the device has been mounted can cause connection problems.
The camera has to be set up though a d-link account to work properly. Elsewhere several users had difficulties when trying to connect the camera using the mydlink home app. Download app
Make sure have that WiFi connection is always connected with camera for the camera to connect correctly. The App works for most smart phones with internet capabilities.
You will find the camera’s Wi-Fi name and password on Quick install card “come with camera on the box.
  1. Connect the camera to your Wi-Fi network
  2. Add your camera to a mydlink account
  3. Access your camera from the App
Motion detection malfunction
Camera fails to detect movement.
Camera Sensitivity
Make sure the sensitivity is in a fitting range. If sensitivity is higher than it is supposed to be this will cause false alert.
Under Setup in the camera interface is where you can manage sensitivity. On the left side, click on Motion Detection, select Enable. Under Sensitivity, enter a percentage. The higher the number the easier the motions will be detected.
Camera too Close to Windows
Set the camera up away from windows. Shadow light movement seems to cause false detection. So setting the camera away from windows can help.
Low quality videos:
Camera is recording grainy or blurry videos.
Not Enough Memory
Use a big memory storage to get more high quality videos.
Not Staying Connected to Wi-Fi
Make sure the camera is always connected to the WiFi and the signal is strong.
Too Close to Windows
Place the camera indoors and away from the glare of windows or glasses.
LED Lights:
This indicator is used to show the availability and strength of the wireless networks. Some users have reported blinking of the indicator while others would like to turn it off.
What the Different Lights Mean
The led lights describe the status for the camera : Blinking Orange means ready but not connected to the WiFi. Solid Green means the camera is connected to the WiFi. Blinking Red LED will blink during the reset process. To replace or remove the indicator, use this guide
Check the password status during the connection
You may need to put the password in again to connect to Wi-Fi.
Not Recording To MicroSD:
You can’t get the camera to record onto SD cards, or any can only get snapshots but not videos.
The most likely cause of being unable to record on a microSD card is that it has not been set up through the camera’s dlink account. This can be done through selecting the settings option for the camera and scrolling to advanced settings in your dlink account.
SD isn't Formatted Correctly
Some users have found that it is not formatted correctly and shows there is no space on the SD.
Open an internet browser and type the IP address of your camera into the address bar. When prompted, enter the username and password for the camera (The default username is admin with no password) Click the Setup Tab and then click SD Management on the left side. Click Format SD Card
Faulty Firmware
The installed firmware may have uploaded incorrectly, or is out of date. Open a web browser, and enter your cameras IP address. Enter your camera's username and password. Click on Maintenance > Firmware Upgrade. Then click Browse, select the downloaded firmware, and then click the upload button.
Author
with
Morgen Jaques
557 Reputation
5 Guides authored
56 Comments
How can I set this up on my phone
Pamela Hodges - Reply Share
Wi-Fi not connecting to my phone.
The camera is connected with WPS, at the light is green. But when I go into the app and want t add a camera, is says:
Cannot connect to camera, Follow the setup guide to restore the connection.
What to do???
Jannie Sørensen - Reply Share
Cameras not recording to cloud during some events… will record before and after
Steve - Reply Share
Mine too, it always seems to miss critical events and times when I've needed to use footage as confirmation there has been people coming and going, it has failed to capture it.
Jennaye - Reply Share
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 246
All Time: 104,906
