My Crosley Will Not Turn On
The device will not turn on when the power button is pushed; the red light indicator does not activate.
Not Plugged In
Make sure the device is plugged into an active outlet.
Power Button Not Activated
Check to see that the power button is pushed in and stays in position and the red light near the button is on.
My Crosley Will Not Produce Sound
The device will turn on, but when trying to play music via the CD, turntable, cassette, auxiliary cable, and/or radio, the device does not emit sound.
Volume Turned Low
Check the volume level by turning the volume knob clockwise.
Line-In Switch Positioned To "Out"
If not using the auxiliary input, make sure the line-in switch, located on the back of the system near the auxiliary cable, is in the off position.
My Turntable Will Not Spin
The device will turn on, but the turntable will not activate/spin after moving the turntable arm to the right.
Make sure the function switch located on the front left of the device is set to phono. Then try moving the turntable arm to the right until you hear a click. Make sure the protective needle cover is removed.
My CD Does Not Play
After inserting a CD correctly, the CD will spin, but does not produce sound.
Make sure function switch on the front left of the device is set to CD. Ensure the surface of the CD is clean and has been inserted correctly with the label side facing up.
My Radio Does Not Play
After turning the device on, the radio will not tune or produce sound.
Function Switch In Wrong Mode
Make sure the function switch located on the front left of the device is on radio mode and select either AM or FM frequency via a small button located on the front of the device. When this button is pushed in, it is in FM mode, when it is pushed out it is in AM mode.
Antenna Is Obstructed/Detached
Ensure that the FM antenna, a thin wire located on the back of the device, is not blocked or detached. Move the wire until you hear clear reception. For AM reception, the unit is provided with a directional built-in ferrite antenna. Rotate the set to find the position in which the best reception is obtained. Do not connect the FM WIRE ANTENNA to any outside antenna.
MarkAnthony
826 Reputation
5 Guides authored
UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013 Member of UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G4
3 Members
60 Guides authored
75 Comments
My crosley is off the red light not turn on "(
Miad - Reply Share
My Crosley is working except for the CD player which opens but does not close when you push the button, you have to put the power of and on. The main problem is the display screen, it just turns green, so no words to see what function was selected, e.g. cd or tuner......
Alta la Grange - Reply Share
So I was messing around with one my grandmother gave to me. She has it in perfect conditions almost never used. I figured out how to start it and then moved more to the right to see if that stopped it. It seems like that broke it as now it wont stop spinning and wont click at all. I got it to stop by wiggling it a little and now it wont start anymore. Any solution?
Marq - Reply Share
under the table there is what I would call a stiff wire actuator rod that slips into a hole at both ends. one end slips into a hole under the counter weight at back of stylus and the opposite end slips into a hole in the little plastic triangular piece under the table. mine slipped out of one of the holes. perhaps there is someone more educated in turntable nomenclatural linguistics that knows what these items are called and can describe it better than I. you guys know what I'm talking about. help this guy out
Jon b - Reply Share
My Crosley radio, cd, cassette, etc. works well. However, when I put a record in the sound is incredible low and max volume setting. The needle is new, the volume works really well on every setting except phono for vynil. Any suggestions?
Charlene Romani - Reply Share
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 103
All Time: 72,908
