Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Unable to Pair Headphones to Device
Headphones are not pairing with device
Low Battery
The battery may be too low for the headphones to properly connect. Try plugging in the headphones using the provided micro-USB charger until the the light by the power connection port turns green.
Dongle is improperly paired
If the headphones still will not pair to your desired device or you have completely replaced the wireless dongle, you may have to manually re-pair the headphones to the wireless dongle.
To pair the device:
  • Plug wireless receiver dongle into computer
  • Locate the tiny hole near the dongle’s LED. Using a paper clip, press the paperclip into the hole until the dongle’s LED blinds rapidly.
  • Hold power button on the side of the headset until the dongle’s LED turns solid.
These steps were taken from Corsair Support, which can be found here.
Muffled or Low Sound
Sound is too low, muffled, or overpowered by background noises.
Low Battery
The battery may be too low for the headphones to properly function. Try plugging in the headphones using the provided micro-USB charger until the the light by the power connection port turns green.
Incompatible System Settings
Poor audio quality could stem from incompatible settings in system software. To resolve, download the CORSAIR Utility Engine software to improve audio quality
  • Locate VOID PRO RGB USB, WIRELESS, SURROUND and follow right hand prompts to download file
  • Default settings are compatible with popular games but may be incompatible with your desired media. Manually adjust volumes, equalizers, and other sound settings on the CUE software. Observe if the issue persists.
Surround Sound Randomly Turns On and Off
The surround sound intermittently turns on and off without prompt, is unresponsive to adjustment or does not work at all.
Low Battery
System Software
This is most likely due to the software that can be addressed in the Corsair Utility Engineering (CUE) software that accompanies the headphones.
To troubleshoot this:
  • Conduct a repair of the CUE that can be found in the Add/Remove Programs.
  • If that does not work, create a new EQ by pressing the ‘+” button lower everything.
  • If nothing changes, try to repair the installation in the Add/remove programs.
This information was taken from a forum that can be found in this link.
Static Noise
Persistent static sound on one or multiple programs.
Operation beyond headphone range
You may be listening too far from the wireless dongle or something is obstructing communication between the headphones and the dongle. Try plugging in the wireless dongle to another closer point or use the dongle extender included with the headphones. Simply plug the dongle into the extension port and plug the extension cable into your device.
Inconsistencies in System Settings
Static sounds could be a result of inconsistencies is system settings, faulty hardware, or a software bug.
  • Make sure microphone check is off in CUE settings.
  • Try different USB ports and different devices to determine if the static is due to an issue with your device or the headphones.
  • Continued static sounds on multiple devices isolates the problem with the headphones. This could point to a problem with the microphone firmware which can be adjusted in the CUE settings until the problem is resolved.
For further instructions, see these forum posts by a COSAIR Representative.
Unprompted switch to Stereo or Bootloader
Headphones switch to different modes randomly.
Unsupported Media Software
Your game or media may not support the headphone’s built in Dolby encoding. Depending on the program, this may be changed in the system settings of the program. More information can be found from this guide.
Pressing down on a button during power up
This happens when you press down any button while plugging in the headset, if you are holding down any button while plugging in the USB, the headset will go into bootloader mode.
To recover:
  • Open up CUE (You will need to have CUE 1.11.85 or newer. You can find the newest version of CUE at corsair.com/download)
  • Go to SETTINGS
  • Under SETTINGS, find and click "DEVICE"
  • Under this screen you will see VOID WIRELESS. Click "Update firmware"
  • Select "Force update from the server" option, and proceed with update
  • Connect headset when prompted in CUE.
  • Let it update.
  • Once the firmware has been updated you will need to put your headset and dongle in pairing mode.
These steps were taken from a forum that can be found here.
Headphones Not Charging
Headphones in Bootloader Mode
If headphones are unable to charge, they may be in bootloader mode.
To recover:
  • Go to SETTINGS
  • Let it update.
Faulty Battery
If refusal to receive or retain charge persists, the battery may be faulty or old. For a step by step guide on parts, tools, and steps follow this link.
Gianna Nobili
854 Reputation
5 Guides authored
Cal Poly, Team S9-G13, Maness Spring 2019 Member of Cal Poly, Team S9-G13, Maness Spring 2019
CPSU-MANESS-S19S9G13
4 Members
72 Guides authored
5 Comments
I dropped my Corsaid VOID headset, and now when I place the mic boom in the down position, it does not activate the microphone, it only activates somewhere up and when the boom is held outward a bit. Is there a switch I can swap out?
Connor Wilkinson - Reply Share
I updated the void pro and when the update finished they stopped working and I have tried the method of the mute button and the one of this article and nothing happened. I dont know if my headsets are in bootloader mode or if it is an unknown problem. Now in the iCUE software in the part of devices it appears me Generic Headset and not Wireless Void Pro RGB, it says me to connect a usb for it to update but i connect it to the headset and nothing happens. I think it is bc the headsets dont turn on. Please someone help!
Wxserr - Reply Share
I seem to be having a similar issue. Just got the new headset and plugged it in to charge. A red light came on. Tried to connect it though the wireless dongle and nothing has worked. Now the light wont even turn on when plugged in. Even if I plug it into the wall.
Hannah Leininger - Reply Share
Any tutorial on servicing the charge port? I was hoping to convert it to something stronger female port as well. Maybe USB-c? Not sure which would be ideal.
Blaire Leingod - Reply Share
My headset suddenly decided to stop charging after 3 years of not-so heavy use. Y'all just helped to keep it going. Much appreciated. The red light is back!
Kevin Michaels - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 53
All Time: 28,360
