Computer Audio Adapter Characteristics
Here are the important characteristics of audio adapters:
Audio channels
It's important that the audio adapter support your speaker configuration. Audio adapters may support any combination of the following configurations:
  • 2.0- front left and right satellites
  • 2.1-2.0 with a subwoofer
  • 4.1-2.1 with a rear left/right satellite pair added
  • 5.1-4.1 with a front center-channel speaker added
  • 6.1-5.1 with a rear center-channel speaker added
  • 7.1-5.1 with a side left/right satellite pair added
  • 8.1-7.1 with a rear center-channel speaker added
Frequency response
The range of human hearing is usually stated as 20 Hz to 20 kHz. All current audio adapters nominally support this range or close to it. However, few cards state dB for that range, which specifies how flat the frequency response curve is. A good card may have frequency response of 20 Hz to 20 kHz at 3 dB. A professional-level card may have frequency response of 20 Hz to 20 kHz at 1 dB down. In expensive cards may claim frequency response of 20 Hz to 20 kHz, but that range may turn out to be stated at 10 dB down or some similarly absurd number, which in effect means that actual usable frequency response may be something like 100 Hz to 10 kHz.
Signal-to-noise ratio
Signal-to-noise ratio (S/N ratio), stated in dB, specifies the amount of signal (data) relative to noise, with higher numbers indicating better performance. A low S/N ratio translates to audible hiss. The best audio adapters have 95 dB or greater S/N for analog audio; midrange adapters about 90 dB; and inexpensive adapters may have 85 dB or less. It's not unusual for a card to have some what lower S/N ratio for digital recording and digital playback. For example, an excellent consumer-grade audio adapter may specify an S/N ratio of 96 dB FS A-weighted for analog audio, 93 dB FS A-weighted for digital recording, and 90 dB FSA weighted for digital playback. In a typical PC environment, noise level (both ambient external audible noise and the electrically noisy inside of the PC) and the typical use of low-quality speakers or headphones make it unlikely that anyone could differentiate between cards with S/N ratios of 80 dB or higher if that were the only difference. However, cards with higher S/N ratios are generally better shielded and use better components, which translates to better sound and less hiss.
Duplex mode
Half-duplex audio adapters can either play sound or capture sound, but not both at the same time. Full-duplex audio adapters do both simultaneously. For simple tasks listening to CDs or playing games a half-duplex card is adequate. More advanced audio functions, such as VoIP telephony and voice recognition, require a full-duplex card. Most midrange and all high-end audio adapters support full-duplex.
Standards compatibility
In the distant past, software wrote directly to the audio adapter. That meant that compatibility with proprietary standards initially AdLib and later Sound Blaster was important, because if your game or application didn't explicitly support your audio adapter, you simply couldn't use sound with that software. Microsoft took the initiative away from audio adapter manufacturers by incorporating standard sound APIs into Windows. Here are the standards you should be aware of:
Microsoft DirectSound
Microsoft DirectSound (DS) is a component of DirectX. Developers can write to the DS API, rather than to the underlying hardware, with the assurance that their software will function with any DS compatible audio adapter. DS compatibility is an absolute requirement for any audio adapter.
Microsoft DirectSound3D
Microsoft DirectSound3D (DS3D) is an extension to DS that supports 3D positional audio, which is a technology that manipulates sound information to extend stereo imaging to full surround sound, allowing sounds to appear to come from any position around you. For example, when in an air combat game your missile hits a bandit in front of you, the sound of that explosion comes from the front. But if you didn't notice his wingman on your six, the sound of his missile blowing off your tail comes from behind. The realism of DS3D imaging in any given situation depends on how many speakers you use and the hardware capabilities of the audio adapter. If you intend to use DS3D-enabled software, it's important to have hardware support for DS3D in your audio adapter, because DS3D positional effects that cannot be processed in hardware are processed by the main CPU, which can bog down system performance.
Creative Labs EAX
Creative Labs EAX (Environmental Audio Extensions) is a proprietary Creative Labs extension to DS3D. EAX 1.0, used by older Creative Labs sound cards, provides reasonable 3D imaging. EAX 2.0 and EAX Advanced HD Multi-Environment are significant enhancements that provide unmatched positional audio performance. Given the dominance of Creative Labs, the various flavors of EAX are widely supported by game software.
Hardware acceleration
Midrange and high-end audio adapters have an on board DSP, which is a general-purpose CPU optimized for processing digital signals, such as audio. In 2D mode, the DSP provides enhanced audio effects like chorus, reverb, and distortion. In 3D mode, it processes 3D-positional audio (e.g., DirectSound 3D or EAX) algorithms locally, removing that burden from the main CPU. Inexpensive audio adapters use the host CPU, which reduces performance significantly, particularly during complex operations such as 3D rendering. Any accelerated audio adapter should accelerate 32 or more DS and DS 3D sound streams in hardware.
More about Computer Audio
Author
with
Sam Goldheart
478,971 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 40
All Time: 2,121
