Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
ColecoVision Troubleshooting
This troubleshooting page will help you diagnose problems with the ColecoVision
Controller is unresponsive at times
When I am playing games, my controller refuses to respond to several commands
Controller needs to be replaced
If after plugging the controller into different ports, you find that it isn't working, simply ordering or buying a replacement controller should solve the issue.
Controller port(s) might need a clean up
Dust can enter the controller port and cause the ColecoVision to have trouble registering the controller.
Tools: Can of compressed air, can of compressed air straw.
Step 1: Unplug the controllers from the controller ports.
Step 2: Insert the can of compressed air straw into the can of compressed air.
Step 3: Using the can of compressed air, insert the straw into the controller ports and spray compressed air around the pins in the controller port.
Step 4: Remove the straw from the controller port and plug the controller back into the controller port.
Controller functions might be stuck from dirt build up
Dirt and crumbs can build up around the keypad buttons and the joystick. Cleaning the controller should restore functionality.
Step 1: Dip a cotton swab into 91% Isopropyl Alcohol.
Step 2: Run the now wet cotton swab over the keypad buttons and joystick.
Step 3: Allow ample time for drying.
Step 4: You controller should now be operating smoothly.
Game cartridges would die
My game console will not read my game cartridges when I insert them into the console
Actual game cartridges may be worn out
If only one game cartridge doesn't read on multiple ColecoVision consoles, the game cartridge may be worn out. Simply buy a replacement cartridge for that game.
NOTE:You will lose your game file progress.
Cartridge reader might need an internal clean up
The game cartridge reader may have dust or dirt preventing the reader from recognizing the game cartridge.
Step 2: Run the now wet cotton swab along the cartridge reader.
Step 3: Allow adequate drying time.
Step 4: Replace cartridge and turn console on.
Cartridge reader is defective
If multiple game cartridges are not being read but work in another ColecoVision console, the cartridge reader may be faulty and need replacing. Replace the cartridge reader using the Cartridge Reader Repair Guide.
Console automatically chooses settings for you without your control
Cursor on screen automatically moves without my consent
Motherboard is faulty
The operation of the console may have become corrupted due to damage to the motherboard. See the Motherboard Replacement Repair Guide.
Rolling picture/video would be unclear or distorted
There are sometimes lines or blurry pictures on screen when I am playing
ColecoVision requires a restart
Sometimes, simply resetting the console will clear the problem. Do this by turning the power Switch "OFF", then "ON".
Television might not be able to support ColecoVision
The television you are playing on may not be able to support the ColecoVision. While the console plugs into the Televsion using a coaxial cable, many converters exist to allow for coaxial to AVI or HDMI conversion.
Coaxial to HDMI or AVI
Check to see if your coaxial cable is plugged into both the console and the converter box correctly and securely. Check to see if your HDMI or AVI cables are plugged in correctly. Check all cables for damage. If all is plugged in correctly, the problem may lie in either of the cables or the converter box. First, try replacing the cables. If the problem persists, try replacing the converter.
Coaxial Cable Only
If using only the coaxial cable, check to see what channel the channel switch (located on the back of the console) is set to the channel you are trying. If switching between channels does not work, simply replace the coaxial cable.
Power switch won’t turn on console
Console will not power on, no matter how many times I reset and unplug it
Plugged into a defective outlet
If your ColecoVision is not turning on, it could be due to a defective outlet in your wall. Try plugging your console into a different outlet. If it is plugged into a powerstrip, either move the powerstrip's plug or remove the ColecoVision from the powerstrip and plug it directly into the wall.
Power cords are faulty
If changing the outlet does not work, the power cord may be at fault. Replacing the cord should solve this issue.
Author
with
Bobby
380 Reputation
2 Guides authored
UW Tacoma, Team S1-G2, Rose Fall 2018 Member of UW Tacoma, Team S1-G2, Rose Fall 2018
UWT-ROSE-F18S1G2
4 Members
72 Guides authored
10 Comments
I am looking for someone that still repairs these. Any information would be appreciated. Thanks, ggbelsky@yahoo.com.
George Belsky - Reply Share
I do repair these. It really depends on issues you’re getting with Coleco. However, I don’t do any repairs if Coleco was modded or attempted to fix. I do attempt repair if console was opened though. Email me at iridude@aol.com
Thomas McCaffery - Reply Share
Maak je ook cbs coleco console. Doet namelijk niks meer
Ralph Jongboom - Reply Share
I live in st. louis MO. Have colecovision with expansion module #1. My kids loved it in the eighties and nineties. I am sure it worked back then but tried hooking it up with new power supply but nothing works. Can you determine if it can be fixed? kekozak2009@yahoo.com
Kenneth & Kathleen E Kozak - Reply Share
Nothing works? Did you try switching from channel 3 and 4? No picture?
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 83
All Time: 6,369
