Most Helpful:
  • CTRL + F
    • This shortcut opens a menu that lets you find text on any page. This helps you find what you need immediately instead of breezing through mumbo-jumbo.
  • CTRL + C
    • This can be used to copy images, text, and more to your 'clipboard'
  • CTRL + V
    • This allows you to paste the last copied data from your 'clipboard'
  • ⌕ + V
    • This opens your 'clipboard' and allows you to see multiple previously copied items
  • CTRL + show windows
    • This allows you to take a screenshot of the entire screen, a certain part, or even start a screen recording
    • The show windows button is likely above the 6 key. This may vary depending on your keyboard or Chromebook model. It shows a rectangle with 2 vertical lines beside it.
  • ⌕ + ALT
    • This turns on 'caps lock'
  • ⌕ + L
    • This relocks your computer, prompting you to reenter your password.
  • CTRL + P
    • Allows you to select a printer to print out your current page
Browser Shortcuts:
  • CTRL + W
    • Closes the current active tab
  • CTRL + T
    • Opens a new tab
  • CTRL + Shift + T
    • Opens the last closed tab
  • CTRL + 9
    • Focuses on the furthest tab to the right
  • CTRL 1-8
    • Focuses on a tab depending on the number you click, ordered from left to right
  • CTRL + Tab
    • Focuses on the tab to the right of your current tab
Fun Shortcuts:
Torture your friends with these.
  • CTRL + ⌕ + H
    • Enter high contrast mode
  • CTRL + SHIFT + Q (tab twice)
    • Force restarts the computer
  • CTRL + ALT + Z
    • Turns on ChromeVox. Annoying if you're not blind.
  • Power + Refresh
    • Force restarts the computer. It can also help a lot of your screen is frozen. If it isn't- well, have fun logging in again.
More to be added. This page is still a work in progress.
Kyeler W
3,315 Reputation
15 Guides authored
Master Techs Member of Master Techs
Community
337 Members
8,294 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 96
All Time: 633
