Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Casio G'zOne Commando 4G LTE Troubleshooting
The Casio G'zOne Commando is a smartphone which is ruggedized and runs the Android operating system. Available on April 28, 2011, the device was released with Android 2.2.1 Froyo operating system, but an upgrade to Android 2.3.3 is available.
Phone Will Not Turn On
My phone will not power on or respond
Double Check
Charge the phone with a charger you know works for a few minutes and make sure that it is not just dead. It may not power on right away but if it doesn’t after fifteen minutes, it is more than just dead.
Remove Battery
Perform a hard reset by removing the battery on your phone. Perhaps the phone itself will turn on but the OS (Operating System) is frozen and the screen won’t light up or respond. To do this you will have to open the phone up and remove the battery. Afterwards, if it is charged, it should power on normally.
Get a New Battery
Your phone battery could also be damaged or dead. In this case, you would have to get a replacement from either online or through your carrier. See our battery replacement guide for instructions.
Speakers are Not Working
I cannot hear my ringtones or my music
Test Volume Buttons
Test the volume is working by pressing the buttons on the side of the phone. For further investigation enter the apps tab, go to settings, then to sound, and then to volume. Adjust volume settings to see if it affects the volume.
Disable Bluetooth
Make sure that the Bluetooth on the phone is turned off. Select the apps tab and then continue to the phone’s settings. From the settings enter the wireless and networks tab and then select the Bluetooth tab. Once in the Bluetooth setting make sure that the arrow next to enable is missing. This signifies that the Bluetooth is turned off.
Power Off Phone
Reset the phone by turning off the phone by using the power button. After the phone is completely turned off, turn the power back on.
Replace Speakers
There may be something wrong with the electronics inside.
Camera Does Not Take Pictures
I cannot take any photos or snapchats with my phone
Clean Lenses
Make sure that there are no obstructions on the camera lenses that include: lens covers, fingerprints, dirt, obstructing phone cases, fingers, and hair. To clean lenses use a microfiber cloth.
Update Firmware
At the home screen go to apps and make sure that the camera app is updated to its latest version.
Clear Memory
If the phone’s memory is full it will not be able to take photos. Go to phone storage in the settings and manage the systems use of memory.
Reset Phone
Lastly reset the phone by turning off the phone by using the power button. After the phone is completely turned off, turn the power back on.
Test Camera Focus
When taking pictures tap the screen to try and bring whatever you are trying to take a picture of in focus. If the camera does not focus, you may need to follow our Camera Replacement Guide and replace your camera lens.
Network Connection Errors
My phone is could not connect to my network
Reset Phone
It is always good practice to reset your phone when it comes to software glitches, as quite often a rest will solve the error. Also, make sure that you have coverage. If you are in a dead zone or you are not on a phone plan, network issues are common.
Perform Factory Data Reset
You may have to perform a factory data reset (NOTE: This will erase all of your apps, media, and system data). To do this, tap the apps tab. From there, tap settings and then tap privacy. From the personal data section, tap Factory Data Reset. Then, tap OK. Tap Reset Phone, then finally Erase All. This will completely wipe system memory.
Remove/Install SIM Card
You may have to remove the SIM card to solve this error. Make sure the device is powered off before proceeding. Follow our SIM Card Removal/Installation guide to safely do this. Afterwards, turn your phone back on.
Daniel Keenan
389 Reputation
2 Guides authored
UMass Dartmouth, Team 1-9, Miles Fall 2015 Member of UMass Dartmouth, Team 1-9, Miles Fall 2015
UMASSD-MILES-F15S1G9
3 Members
60 Guides authored
3 Comments
Network Connection Errors: I tried all the above for the error, still have the error, any other suggestions?
bernmntsa - Reply Share
My Gz One Commando rings and vibrates. I answer the phone.
It does not connect. The caller still hears my phone ringing.
John Sconzo - Reply Share
Inside the divice of android u I want to cut the the the Bluetooth service of now
Austin Paulsen - Reply Share
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 28
All Time: 4,403
