Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Blurry Photos
Photos have blurry resolution despite the camera having a built in stabilizer
Canon suggests the usage of a tripod
A tripod can dramatically increase the steadiness of a shot and its clarity. Pictures taken with extended zoom are more susceptible to blurriness and will require a tripod to improve stabilization.
For more helpful tips on how to better use your camera, please visit:
http://www.cnet.com/products/canon-power...
Memory card error
Camera LCD screen displays memory card error message and will not store pictures.
Reinsert memory card
The memory card is orientation sensitive; make sure the memory card is aligned properly in the memory card slot. Try removing the memory card and putting it back into the memory card slot to see if that positions it correctly to work again.
Or try restarting the camera with the memory card in it, if memory card is not recognized.
Format memory card
Formatting a memory card from camera settings should alleviate any potential errors. This will reset the memory card and bring the memory card back to its original state.
Slow Processing Pictures
Camera takes too much time to process photos after taking a picture.
Slow memory card
Try using a memory card at a class 6 level or higher to improve processing speed. A faster card can operate and higher speeds and reduce lag time. Remove the former memory card and replace it with the new higher level memory card.
LCD screen not working
Screen is no longer functioning or is heavily pixilated.
Possible underlying causes to check:
Check battery life
Remove the battery, charge it and then reinsert it back into the camera. A drained battery will prevent the camera and the LCD screen from operating. The camera needs a charged battery in order to operate.
Broken LCD screen
A cracked or non-functioning LCD screen will require replacement. A cracked screen should be replaced in order to restore clarity and improve viewing quality.
Bad connection from LCD screen to motherboard
The LCD screen can disconnect from the motherboard and will require replacement components in order to fix the connection. Either the connection at the motherboard or at the LCD screen are disconnected and no longer operate as a unit.
Power not lasting
Battery life is quickly drained.
Reduce resolution or reduce video recording usage
Higher resolution pictures and using the video recording feature will drain the battery quicker than lower resolution photos. Limit extended periods of usage and frequency of shots to extend battery life.
Other things to check:
Make sure the battery is charged fully.
Check to see if the battery is inserted facing the right way.
Clean any dirty battery terminals with a cotton swab.
Battery performance decreases with a low temperature, so try warming it a little in your pocket, with the terminal cover on the battery.
If changing the battery doesn't work, then it has died and a new one needs to be purchased.
Buy back-up batteries
Back-up batteries will allow the user to exchange batteries when one is drained.
For a complete guide on your camera, please visit:
https://www.manualowl.com/m/Canon/PowerS....
3 Comments
I have a red, almost like a laser line throughout all of my photos..What could that be?
Vanessa
vwilson@lifestylera.ca
greenbutterflies56 - Reply Share
my doesnt power on.is it other way to power on my camera like by usb connection?
Dipesh lama syangtan - Reply Share
my camera if i press shoot button half way in it will not foces tx Johan
Johan Momberg - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 23
All Time: 3,057
