Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Camera will not turn on
After pressing the on/off button, the camera fails to turn on.
Battery
The problem could be the battery. Remove the battery and make sure it is fully charged. Additionally, make sure the battery and the battery compartment is free of dirt and grime. Ensure that the battery compartment is securely closed and press the power button again.
Camera fails to capture photos
After pressing the shutter button, photos are not being taken.
Wrong photography mode
Make sure that the camera is not in video or playback mode. Turn the mode dial to the green Auto icon and fully press the shutter button. A shutter sound should play and your image should appear.
SD card full
If the SD card’s memory is full, the camera will no longer be able to capture photos. Using the software and the interface cable included with your camera, transfer the pictures from your camera to your computer and then delete the pictures off of your device. You will then be able to capture more photos.
Photos are too dark or too light
After pressing the shutter button, the photo captured is darker or lighter than it appears.
Flash
If the photo is too dark, flash is needed to make the picture lighter. Lift the flash panel located on the top right side of the camera. When you capture the photo the flash will shine and the photo will appear lighter. If the photo is too light, the flash needs to be turned off. Lower the flash panel manually by pushing it down. Then capture the photo. The flash will not shine and the photo will be darker.
Brightness
The screen brightness on the camera could be either too low or too high. To adjust the brightness, press the MENU button located on the bottom right of the camera. Choose the “LCD Brightness” option on the submenu. Using the textured dial, adjust the brightness of the camera.
Photos are blurry
After pressing the shutter button, the photo captured is blurry.
Camera is not focused
If photos appear blurry, the camera may need to be focused. To focus the device, press the shutter button halfway. The camera will then beep twice and the photo should now be clear when captured.
Dirty lens
The camera lens may be dirty or dusty. Use a soft cloth to clean the lens then try to capture your photo again.
Photos are far away
After pressing the shutter button, the photo captured is far away.
Zoom
If the object trying to be captured is far away, the camera will need to zoom in closer to the object. To zoom in, press the MENU button on the bottom right of the camera. Choose the “Digital Zoom” option on the submenu. Using the textured dial, adjust the magnification. Press the MENU button again and the view should be zoomed in on the object.
KeShayla Thomas
281 Reputation
1 Guide authored
1 Comment
lens error camera will shut down automatically
this is the error
Info |Dana Hypermarket - Reply Share
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 42
All Time: 2,794
