Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The Camera Won’t Turn On
When you press the power button, the camera won't turn on.
The Battery Is Inserted Backwards
If the battery is inserted backwards, then the camera will not turn on. Check that the battery is placed correctly inside the camera.
The Battery Cover Is Not Properly Closed
If the battery cover is not properly closed, then the battery may not be connected properly and the camera won’t turn on. Make sure that the battery cover is closed correctly.
The Battery Is Not Charged
If the battery is too low on energy, then the camera won’t turn on. Remove and recharge the battery for 20 minutes, reinsert the battery, secure the cover, and try to turn the camera back on. If the camera turns on, then the battery has low power and should be recharged completely.
The Battery Or Charger Is Broken
If the camera still does not turn on, then the battery or battery charger may be broken and should be replaced.
The Motherboard Is Damaged
If the motherboard has suffered water damage or physical damage from hard contact with surfaces, then the camera may fail to turn on. In this case the camera may have to be replaced.
A Lens Error Message Appears On The Screen
There was a widespread problem with this camera’s lens that affected specific batches of cameras. The screen identifies the error as a “Lens Error.” However, the lens may need to be replaced entirely. Canon discusses this specific issue on this page.
The Lens Won’t Retract
When you turn off the camera, the lens remains extended.
The Battery Cover Was Opened While The Camera Was On
To resolve this issue first sure that the camera is turned off. Then open the battery cover, and remove and reinsert the battery and the memory card. Close the battery cover completely. Turn the camera on and then turn the camera off again. If this does not retract the lens, the lens may be broken and might need to be replaced.
The LCD Screen Won’t Turn On
Nothing displays on the LCD screen when your camera is in use.
The Camera Is Off
If the camera is off, the screen won’t display anything. Make sure the camera is turned on by pressing the power button
The Screen Is Cracked
If the screen is cracked or damaged, then it may not display anything. Follow this guide to replace the LCD screen.
The Pictures Appear Blurry
Pictures you take appear blurry when they are displayed on the LCD screen or when you print them.
The Screen Is Dirty
Pictures may appear blurry if the LCD screen is dirty. Clean the LCD screen with a soft cloth, such as a microfiber cloth.
The Lens Is Dirty
The camera may be capturing blurry photos if the lens is dirty. Clean the lens with a soft cloth, such as a microfiber cloth.
Using Autofocus Incorrectly
The camera has a focus feature that is activated by pressing the shutter button halfway. Make sure to depress the shutter button half way, and hold it there for a moment, before fully depressing it to take the photo.
In Bad Lighting Conditions
Sometimes photos don’t come out desirable because of insufficient lighting. If you are indoors, or in a dark environment, using the flash may help.
Using A Slow Shutter Speed
The camera’s capture settings may also be effecting the quality of the photos. Reviewing the “Setting the Shutter Speed” portion of the user manual may also help.
The 'Memory Card Full' Message Appears On Screen
When I try to take pictures or videos, the LCD screen on my camera displays a 'Memory Card Full' message.
Too Many Pictures Are On The Memory Card
If the camera's memory card is full, it will not allow you to take additional pictures or videos. If you don't want to delete any previous photos, an additional memory card can be purchased. A more practical option is to move photos and videos from the camera to a computer or laptop. To move content from the camera to a computer, connect the camera to a computer using the USB cable that came with the camera. Once connected, follow the instructions on your computer for opening picture and video files. Cut the content you want to keep and paste it into any desired file on your computer.
Shannon Farwell
163 Reputation
0 Guides authored
USF Tampa, Team 1-4, Leahy Winter 2015 Member of USF Tampa, Team 1-4, Leahy Winter 2015
USFT-LEAHY-W15S1G4
4 Members
60 Guides authored
1 Comment
Should the camera still work if it's plugged into the mains and the battery is broken
Chris - Reply Share
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 96
All Time: 11,500
