Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Canon PowerShot G1 X Troubleshooting
This troubleshooting page will help you asses and diagnose problems with the Canon PowerShot G1 X.
Camera Will Not Power On
Camera will not respond to any attempt to power on.
Faulty Charging Cable
Your battery may not be getting a sufficient charge from the charging cable. Check for ruptured wiring or a broken adapter tip.
Faulty Battery
If you have ensured the power adapter is capable of charging, but when attempting to use the charged battery the camera does no power on you may have a faulty battery. Try purchasing or using another battery that is compliant with your device.
Keypad buttons are not responding
The buttons on the cameras keypad next to the screen will not respond to touch.
Dust or Material Under Keys
If the buttons are not responding there may be dust or debris behind the keys keeping the button from reaching the sensor underneath the key. Try using some compressed air and to spray the keys to dislodge or remove the debris. If there is a sticky substance try using a Microfiber cleaning cloth with some lens cleaner.
Missing Keys
If there are any keys missing it is recommended you replace them to reduce the amount of dust and debris that may enter the camera and affect other keys.
LCD screen display will not turn on
When powering on the camera the screen will not power on or is not bright enough to see.
Broken LCD Screen
Your LCD screen may be broken and should be replaced in order to view and edit photos.
Back-light is too low
The back-light for the viewing screen may be set too low for you to properly see in bright lighting. You may need to change the backlight settings so that your screen can be viewed. You can do this by navigating to the settings tab on your camera.
Camera Flash Failing
When taking pictures the flash will not go off.
Flash setting may be off
Check to be sure that the flash is not set in the off position or that the camera mode you are using do not use a flash. Sometimes if the sensor on the camera detects a certain amount of light the flash will not go off depending on which mode you are in. There is also a micro sensor on the top of the camera that may need to be uncovered in order for the flash to work. This sensor is to the right of the pop up flash on the top of the camera above the lens.
Flash is broken
If the light for you flash is blown or broken it may need to be replaced.
Optical Zoom Does Not Focus
When zooming in the picture seems blurry or distorted in some way.
Check your settings
Your camera may be having trouble focusing if you are using manual settings for certain distances. Try switching to auto or another mode to see if the focus becomes clearer.
Author
with
Cleston Sanders
124 Reputation
1 Guide authored
USF Tampa, Team 20-1, Remmell Spring 2017 Member of USF Tampa, Team 20-1, Remmell Spring 2017
USFT-REMMELL-S17S20G1
3 Members
48 Guides authored
3 Comments
Has anyone had problems with the zoom lens. I can shoot at regular of fully zoomed. Nothing in between. And, once i zoom in, i cannot zoom back out without shutting the camera off.
Bill A=D - Reply Share
I connect the camera in its stowed position and it works perfectly. But if I move the screen it turns off and so does the camera.
Pedro Luengo Flores - Reply Share
الكاميرا لن تعمل
لن تستجيب الكاميرا لأي محاولة للتشغيل.
ahmed.ba.good - Reply Share
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 44
All Time: 1,769
