Device Won't Turn On
Check the Battery
Check that the batteries are not dead. Replace batteries with four new AA alkaline batteries. Check if batteries are placed in the right direction. Rechargeable batteries may also be used and Canon AA-size NiMH batteries are recommended.
Check Battery Cover
Make sure the battery cover is tightly closed. Also, inspect the battery housing for any corrosion or bent components.
CMOS Battery
There is an internal battery that may be check or replaced on the motherboard. Refer to the Camera Housing iFixit Guide for location.
Black Screen on Power Up
Low Battery
Dim Screen
Environment
The LCD monitor image will darken in strong sunlight or bright light according to the manufactured settings and indicates normal operation under these conditions.
No Flash
Check Battery
Check that the batteries are not dead. Replace batteries with four new AA alkaline batteries. Check that batteries are placed in the right direction. Rechargeable batteries may also be used and Canon AA-size NiMH batteries are recommended.
Check Camera Settings
Press the function set button and scroll down to the flash output menu. Once there, press the function set button again to turn on the flash.
Replace Bulb
The flash bulb may burn out if used often. When this occurs the bulb must be replaced.
No Sound
Warning sounds still play, but start-up, operation, self-timer, and shutter sounds are mute.
Open the menu by pressing the bottom button labeled menu. Press the right directional button to move to the setup menu. Press down to scroll to the mute option and check if it is enabled. If it is, highlight the mute setting and press the function set button to toggle off mute.
Author
with
Jaime Abraham
350 Reputation
3 Guides authored
CSU Fullerton, Team 1-1, Bruce Fall 2014 Member of CSU Fullerton, Team 1-1, Bruce Fall 2014
CSUF-BRUCE-F14S1G1
3 Members
36 Guides authored
2 Comments
My canon Pwershot A620 camera turns on but the lens won't activate. The message is that the mechanism has sand or something like that preventing it from opening.
This sounded like the camera was fine and just needs a cleaning which is impossible for a non-professional to do but the guy at the camera store says no one will repair it or it will cost more than a new camera. Really?
Elizabeth
lizabeta2000li - Reply Share
I got a powershot from a thrift store and the batteries left in it were corroded. After changing the batteries the camera still wouldn’t turn on, so I tried to clean it up a bit. It still wouldn’t work. Does anyone know what’s going on and/or know how to fix it?
ruby - Reply Share
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 75
All Time: 3,103
