Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Go to the Canon EOS Rebel XS device page
Camera does not turn on
Camera does not appear to be powering on.
Camera in lock position
Move the command dial to something other than the L position to turn the camera on.
Bad batteries
Make sure that the batteries are fresh and placed into the camera correctly. The camera has an internal battery as well as an external. the internal battery has a lifespan of about 5 years; if your camera is well over 5 years old, the backup battery can short-circuit, preventing the camera from starting up.
LCD Broken
If the LCD is not working, the camera may appear to be off. Try pressing the shutter button and listen for the camera shutter sound to make sure that it is the LCD that is broken and not something else.
Wiring or motherboard problems
If all else fails, it likely you have an issue with the camera's wires or components on the motherboard may have come loose or damaged.
LCD doesn't turn on
Nothing appears on the LCD.
Bad batteries
Make sure that the batteries are fresh and put into the camera correctly. Also make sure that the battery contacts are clean. Clean with a dry cloth.
Old LCD
After 5 years, the LCD may be difficult to read. Replace the LCD. For instructions on how to replace the LCD.
A wire or component on the motherboard may have come loose. If not, a component on the motherboard could have gone bad.
Flash bulb doesn't pop up
The flash bulb wont pop up
Bad batteries
Make sure that the batteries are new and placed into the camera correctly. Also make sure that the battery contacts are clean. Clean with a dry cloth.
Push down the flash button
The flash button can be pressed to make the flash bulb pop up. The flash button can be found on the front, left side of your camera marked with a bolt-like arrow.
Put camera in full auto, portrait, or macro mode
To test if the flash will automatically pop up, the command dial must be set to full auto mode (green frame), portrait (face), or macro (flower).
Flash is stuck
The flash may be jammed, closed, or stuck on something. Make sure nothing is in the way of the movement of the flash popping up. If the flash is stuck on the inside, gently tug on the flash to try to pop it up. If that doesn't work, the camera may have to be opened up.
Camera will not auto-focus
''Camera doesn't auto-focus when in auto-focus mode, but can manually focus when in manual focus mode."
Lens in manual focus mode
If your camera is set to manual focus (MF), it will not focus on its own. Make sure the "AF" mode is selected not "MF" (look above the stabilizer switch on connector lens.)
Push shutter button half way
To auto focus in auto focus mode, the shutter button needs to be pushed half way down while the brackets in the viewfinder are on the object you want to focus on.
AE/AF Lock Settings
If your mode dial is set to 'P', it means that your AF is now being overridden to Program AE which automatically corrects the shutter speed and aperture. Try turning this setting off if its on and you're having problems with your AF.
Focus Ring Stuck
The outer focus ring (located at the end of the lens) can sometimes get stuck, which will prevent your camera from adjusting itself. To fix this problem, set your camera to Manual Focus (MF), hold the end of the lens, and gently wiggle it to try and unstick the focus ring.
Battery cover doesn't close properly
Battery cover does not completely close or broken off
Something blocking the battery door
The battery door may be blocked by something. Check for obstructions around the hinge and the door. Also, the batteries being used may not be of the right size. Use the correct battery type for the camera.
Battery cover latch problems
The spring loaded latch doesn't open and close correctly. The spring inside may be worn or broken.
Broken battery cover hinge
The battery cover hinge my be broken. Check if the hinge is tearing or if completely broken off.
Third Party Battery Compatibility Issues
Canon Rebel XS uses a CR123 battery. It is highly recommended that you use a Canon Brand battery as other brands often have faulty connectors to the charging port.
Charging Port is Dirty, Broke, or Damaged
Even if your battery is new and appropriate for the camera, it could be lacking charge to power on. This could also be because your charging port isn't connecting with the battery because of a damaged bus meant for receiving power from the battery.
Error 99
When trying to take pictures, you receive an error message “Err 99."
Time-out sequencing
When turning your camera on and shooting a picture, you might get an error message “Err 99”, this could be caused by your camera timing itself out. When you leave the power on and the camera times itself out, the motherboard can no longer recognize the flash card which is a fairly big problem with the picture-taking process. To fix this problem, you can simply leave the power switch on, open the flash card door, and then close the door. Once you’ve done that you should be able to take pictures normally again. To adjust your time-out settings, go to ‘Menu’ >> ‘Settings’ >> ‘Auto power off’ and then select the amount of time you’d like the camera to wait before automatically powering off from being idle.
SD card problem
If your memory card is damaged/defective, you will not have anywhere to store the pictures you take. When trying to take a picture, you see an “Err 99” message, first try removing and reinstalling your memory card to the camera. If this does not work, try using a new memory card.
Motherboard problems
If none of the above worked, it is very likely there is a problem with the motherboard of your camera. If the picture you take cannot be transferred from the RAM to the memory card, the camera won’t be able to store the image to anything and you will get an “Err 99” error message. It is possible the motherboard needs to be inspected for functionality, seek a professional for assistance.
Daniel Bussone
1,289 Reputation
11 Guides authored
Cal Poly, Team 3-41, Regan Winter 2011 Member of Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
2 Members
132 Guides authored
19 Comments
Help. My canon xs eos just stopped taking the pics it turns on and u can view the pics
Heidi - Reply Share
Mine too has anyone gotten back to you?
Laura - Reply Share
I have a Canon EOS Rebel XS that I love but it has stop working. When I put my memory card in it say's "NO CARD". Is that a way to have this fixed? Please help!!!
Susie Young - Reply Share
I have the same problem. I tried three cards but none work. I also opened the cards prior to inserting into camera. Any ideas?
Rick Henderson - Reply Share
My canon XS EOS stopped taking pictures, it will turn on and you can view the pics and download to the computer. Will not autofocus or allow pics to be taken.
Kathy LouAllen - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 30
All Time: 74,252
