Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Camera will not turn on
The device will not turn on when the power button is pressed
Dead battery
This may be due to the fact that the battery is dead. You will need to take the battery out of the bottom of the camera and charge it. Once the battery is charged, put it back in the camera and turn it on.
Needs to Reboot
Remove the memory card from the camera. Leave it for 10-15 minutes and then re-insert it and power the device on. You may need to input date and time again.
Needs to Connect to Computer
Connect the camera to your computer using the USB cable. After it is connected for a couple of minutes, try turning on the camera.
Flash on camera will not pop up
When you try to take a picture the flash will not open
Flash Button Needs to be Pressed
Push the flash button (has an icon next to it that looks like a lightning bolt) on the front of the camera next to the lens to activate the flash.
Obstruction to the Flash
Make sure that there is nothing obstructing the flash. If nothing is in the way, gently pull on it to try and get it to pop up.
Wrong camera settings
Change the camera setting to full auto (green frame), portrait (face), or macro mode (flower) to activate the flash to pop up.
Error 99 message
When trying to take pictures the message "Error 99 shooting not possible" pops up.
Camera needs to Reboot
Turn the camera off, take out the battery, and then turn the device back on again. If that does not work, it may be required to sit with the camera off and battery out for approximately 20 minutes.
Problem with the Lens
Try cleaning the lens with a soft cloth. If this does not help, then try using a different lens on the camera.
Problem with the Memory Card
Try using a different memory card or reformatting your old one (this will erase all of your pictures so be sure to save them on a computer first.)
Autofocus not working
The camera will not autofocus.
Dirty Lens
The first thing to try if autofocus is not working is to simply clean the lens with a soft cloth.
Wrong Mode Setting
If the camera is set to "MF" then it will not autofocus. Be sure to set the camera mode to "AF."
Wrong Setting
Go to settings in [C.Fn-9] and make sure it is set to option 0 (AF/AE lock).
Problem with the Flex Cable
Follow this link to replace the flex cable. Flex Cable Replacement
No Response From Shutter Button
The shutter button has no effect and won't take a picture
Take the battery out for about 30 seconds and then put it back in.
Problem with the lens
Try swapping lenses to make sure that it's a problem with the camera.
Problem with autofocus
Make sure that there is enough light for the camera to focus. If that doesn't work, try switching to manual focus or "Al Servo" mode in case it's a problem with autofocus.
Lauren
251 Reputation
0 Guides authored
CSU Fullerton, Team 1-4, Bruce Fall 2014 Member of CSU Fullerton, Team 1-4, Bruce Fall 2014
CSUF-BRUCE-F14S1G4
3 Members
0 Guides authored
7 Comments
Camera always shows error #99
Byron Hill - Reply Share
My Canon Eos Xsi always shows "error" 99 when I try to use it - even with the lens detached
Keep getting “ card wright protected” msg. on new and used cards. lock on card is off.
Barry Anderson - Reply Share
Hi Error 99, lens contact points cleaned, new battery. observation is the mirror is popped up and not set at the bottom.
paul vincent anover - Reply Share
Hey guys. I got a canon 450D for cheap and it turns outits not working properly lol…. When i take pictures through the view finder the image shakes and comes out blurry but when i take images using live view they come out crisp and sharp and just right… im stuck wondering what the problem could be and how to fix it…. Thanks in advance
Donald Maviza - Reply Share
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 54
All Time: 7,679
