"Note:" This troubleshooting guide covers only the Canon EOS Rebel T1i . Other Canon Camera models will be covered in separate troubleshooting guides.
Broken/Cracked LCD Screen
My camera has a broken or cracked screen.
Dropped Camera
If your LCD screen is cracked or broken, you will probably need to replace the entire camera's screen. Visit the repacement guide on Canon EOS Rebel T1i Front Screen Replacement .
My Camera Won't Turn On
I can't get my EOS Rebel T1i to turn on.
Drained Battery
If your camera won't turn on, the battery might need to be charged. Try to charge your battery before you tear down your device. For instructions on how to recharge your battery, check the camera's manual: Canon EOS Rebel T1i / EOS 500D Instruction Manual
Bad Battery
If you tried to recharge your battery and your camera still won't turn on, it is possible that the battery is not recharging anymore and you will need to get a new one. Visit the replacement guide on Canon EOS Rebel T1i Battery Replacement
My Flash is Not Working
I can shoot pictures, but my flash is not working.
Switch on Flash Mode
Sometimes when you set the camera to auto mode, the flash will not work because the camera assumes there is enough light in the room that the flash is not needed. Try switching on the flash mode. For instructions, visit Canon EOS Rebel T1i / EOS 500D Instruction Manual .
Dirty/Broken Flash Spring
When the flash is on, a spring activates the flash compartment, which makes it pop up. If the spring is dirty or broken, you can take three actions: (1) GENTLY try to open the flash compartment when shooting a picture; (2) Clean the area of the spring: (3) Replace the spring.
All My Pictures Are Turning out Blurry
Whenever I take a picture, they all come out blurry.
Low Shutter Speed
Your shutter speed may be too low. Try switching the camera to a setting with faster shutter speed, like the “sports” shooting setting, or manually increasing the shutter speed. Also, if you are shooting in a darker room, you can increase your ISO setting, which increases the camera’s sensitivity to light and allows it to capture the photos faster. For instructions, visit Canon EOS Rebel T1i / EOS 500D Instruction Manual .
Set Lens to Focus Automatically
If you set your lens to manual mode, the camera will not focus automatically. If you don't manually focus the the lens by rotating it, all your pictures will come out blurry because they are out of focus. You can set your camera to focus automatically by switching your lens from "MF" to "AF." Visit Canon EOS Rebel T1i / EOS 500D Instruction Manual for instructions.
My Camera is not Saving Pictures
My camera will not save any photos that I take.
Memory card is loose
If your pictures don't save, try taking out the memory card of your camera and putting it back in. Try taking a couple of photos to check if it is saving the images now. For instructions visit Canon EOS Rebel T1i / EOS 500D Instruction Manual
My Camara's Eyepiece is Loose
"The eyepiece on my camera is damaged."
Dropped Camera
If you dropped your camera on a hard surface it could have landed on the eyepiece, or something could have hit it while you had your camera in your purse/backpack. It is likely that you need to replace your eyepiece. Visit Canon EOS Rebel T1i Eyepiece Replacement, and follow the easy steps on how to replace your eyepiece
My Camera's Grip is Damaged
"The rubber grip on my camera is coming off, or it is damaged."
Nornal Wear and Tear
The rubber grip is usually damaged when you are using the camera. You might have scratched it with your nails as well as pulled one of the edges out. The best choice to fix a rubber grip is by replacing it because your camera will look better and you it will be more secure in your hands. For instructions on how to replace your rubber grip, visit Canon EOS Rebel T1i Rubber Grip Replacement
Renan
99 Reputation
0 Guides authored
Cal Poly, Team 3-41, Maness Spring 2014 Member of Cal Poly, Team 3-41, Maness Spring 2014
CPSU-MANESS-S14S3G41
4 Members
60 Guides authored
17 Comments
Camera wont power on.
we took camera from cool/ac indoors to warm/humid outdoors at the beach. lenses all fogged up and camera stopped working. now the camera will not even power on. have replaced battery with fully charged one and cleaned battery terminals inside camera and on battery, no joy. also removed,cleaned and reinstalled memory card without success. no apparent physical damage to camera body or lense.
Dallas Fox - Reply Share
Same here... Did u figure it out?
Freddy Prospero - Reply Share
same here ... please let me know if you know what happened or what because i bought a new battery as well and it still wont power on
wizardofauctions - Reply Share
When shooting in autofocus the camera won't focus it acts like it's trying to focus but just won't how do I fix?
candace - Reply Share
In my case when i turned on my camera it opened but when tried to click picture it went of and doesnot turn on .I tried removing battery and memory card,and again put them back and it donot turned on. then i charged battery and put it .Camera turned on but while i try to click it goes off like same
pleasehelp
prabin kandel - Reply Share
Past 24 Hours: 0
Past 7 Days: 17
Past 30 Days: 62
All Time: 11,835
