Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Printer Does Not Have Power
The printer will not respond or show any sign of powering up.
Power Adapter
Ensure the power adapter is plugged in and the indicator light is green.
Power Cord
Be sure that the power cord is plugged in to the power adapter and that they are plugged in to a standard power outlet.
Printer’s Indicator is Blinking Red
There is a malfunction in the printer.
Red Indicator Light Without Error Message
Remove the paper from the paper-handling slot and take up any slack within the ink sheet. Turn the printer’s power off and turn it on again.
Printer Does Not Print
The printer might not be connected correctly. Batteries could also be the issue. Overheating of the printer can also cause it to stop printing.
Printer Is Not Correctly Connected
Connect the cable correctly. There will be symbols notifying whether or not the cable is connected properly.
Camera’s Batteries Are Dead
Replace with fully charged, fresh batteries, or plug the camera into a power outlet by using the camera’s optional compact power adapter.
Printer’s Battery Pack is Depleted
Use a fully charged battery pack or use the printer’s compact power adapter.
Ink Cassette is Not Loaded Correctly
Remove and reinsert ink cassette properly.
Printing stopped midway
Printing did not fully finish and is stalled.
Printer is Not Correctly Connected to the Camera
Ensure that the cable is correctly connected and did not disconnect during print.
Print Quality is Not Good
Incorrect Paper Type
Make sure the correct type of paper is being used and make sure the paper isn’t dirty to get the best quality print.
Paper is Loaded With the Wrong Side Up
Load the paper with the correct side up. Click this link http://google.com to learn how to properly load paper.
Ink Sheet or Paper is Dirty
Use a clean ink sheet and clean paper. Discard dirty paper.
Condensation Has Formed Inside the Printer
Wait for condensation to evaporate.
Author
with
Annyn Sparling
101 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 23
All Time: 696
