Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
System unresponsive
The Bose SoundDock XT will not function and is unresponsive.
Faulty power connectors
Before taking the system apart, be sure that all connectors, cords and plugs are inserted properly and the power source is working correctly.
Interrupted connection
Unplug the power connector for a few seconds, then reconnect. This allows the unit to reset after a power interruption.
No source
Make sure that an audio source is selected that corresponds to the desired function (i.e. CD, AM/FM, etc.)
Distorted sound, or no sound, is emitted from speakers
No matter what you do the Bose SoundDock XT plays the distorted or no music when a device is connected.
Defective wiring and/or speakers
When the speakers do not emit sound when a device is on play, check motherboard for possible misconnection or wire damage.
Speaker plays distorted sound
When the sound quality is distorted or fuzzy, check speakers for any damage and test effectiveness. The distortion may be coming from the audio source as well.
Speaker does not play sound
When no sound is emitted, check the volume controls to be sure it is not muted. Check all connections to be sure they are not damaged, and reduce any interference of external devices.
Device will not connect to the Bose SoundDock XT
The device will not connect to the dock, after multiple attempts.
Accessory is not accessible
Before taking the SoundDock XT apart, try disconnecting and reconnecting the device.
Broken Lightning connector
If a device refuses to charge or connect you will need to take apart the SoundDock XT and replace the lightning connector manually.
Incorrect input selected
Be sure that the correct input has been selected and the device has been placed securely and properly.
Cannot connect to another source
The external device is playing, but no sound is heard.
Incorrect cable
Be sure to use the correct 3.5 mm audio cable to connect an external device. The 3.5 mm audio cable must be securely connected to both devices.
Audio jack obscured
Be sure the connector is properly plugged in to the audio jack, if the problem still occurs check for obstruction of the audio jack, which may need for the SoundDock XT to be disassembled.
Device not connected
Be sure the external audio source is on play mode and no other devices are interfering with the connection.
Author
with
Justin Lazaro
37 Reputation
0 Guides authored
IUPUI, Team 1-4, Hagerty Fall 2015 Member of IUPUI, Team 1-4, Hagerty Fall 2015
IUPUI-HAGERTY-F15S1G4
5 Members
36 Guides authored
2 Comments
The lightning connector of mine is broken, where do can I buy this part?
Tomas Varela - Reply Share
Where can I buy the lightning connector for this product?
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 50
All Time: 5,039
